Medic21
They must not be updated. They actually met the specs last year, first to do so.
remember you will be using 160-190 degree water to heat 120 degree water. You will be fine with 1” and a 15-58 pump to get what you want. A 40 plate with 1” mpt fittings is rated at 160,000btu at 180 degree water. 80 plate is overkill.
I’d never turn you away from going with bigger pipe if there was a chance things could change in the future though.
