GG Woody
So sticky... The Spruce is so sticky, so much sap, I regret every one I touch...Pine and spruce are 2 different animals.
Spruce is low on the totem pole. Comparatively, pines are heaven sent.
I find pines, in general, much, much, worse.So sticky... The Spruce is so sticky, so much sap, I regret every one I touch...
nomen est omen?pitch pine
Nah, they're ok.I find pines, in general, much, much, worse.
I never got the Latin names down.nomen est omen?
Try climbing them for a living.... in July and August.Nah, they're ok.
It's not a name, it's a quote. Literally saying "The name is a sign" meaning "The name speaks for itself".I never got the Latin names down.
Well, I meant ok as firewood.Try climbing them for a living.... in July and August.
Not in our neck of the woods.![]()
Pinus rigida - Wikipedia
en.wikipedia.org
I should have stated my remarks reflect my experience from a cold start.Really?
All I burn is southern pine harvested from dead trees, well dried, of course, and it lights off immediately during the reload. So does the cat.
I'm with @Ashful, if the cat's inactive when I reload, I don't wait until the gauge shows active, I know it's going to become active even below the active zone. As mentioned, looking at the cat is a good indication, if it's glowing (even only in places), all's good.
I took an injury while loading a stove last year, that was bad enough I'm still a little gun-shy. Since I have been burning a crap ton of shagbark hickory the last two years, your comment makes me think that must've been what I had in the stove at the time.Ooo man SB hickory. I burned a couple cord of that last season. From what I recall lots of ash, tons of coals and watch out for the 4th of July spectacular when using your poker on reloads.
Sorry to hear that. Honestly a face shield may not be a bad idea! I can see that happening with the way it throws a shower of sparks. My remedy was I’d figure out which one was offending, open the door just enough to get a new split on top of it. I have not burned much black locust but I read that’s another one that likes to let you know it’s in there.I took an injury while loading a stove last year, that was bad enough I'm still a little gun-shy. Since I have been burning a crap ton of shagbark hickory the last two years, your comment makes me think that must've been what I had in the stove at the time.
I had opened the door to load, and was doing my usual routine of plowing the ash toward the back and raking the coals forward, when one exploded quite violently, and struck me straight in the eye. It happened so fast, like paintball gun velocity, that I had no chance at all to even blink before the hot coal hit me right in the pupil.
Hurt like a mother, probably some combination of a scratch and a burn, with a little bit of cinder left behind for good measure. My eye wasn't right for several days after, but seemed to heal just fine after a few days of watering and discomfort. To this day, I wonder if I should be wearing glasses, or a damn face shield, to reload!![]()
Good point. Those clamp-on bucket forks are a) not very safe and b) a good way to bend your bucket edge.And no, before anyone asks... those aren't "bucket forks".
She can do it! I test-drove your 2038R before buying, and really liked it a lot. The ergonomics and visibility of the 2R series is much better than the 3R series, it's a much nicer machine for daily chores and climbing on/off.Was very pleased that the tractor was able to lift the tote with (dried) pine...
You closed your bypass with the gauge that far in the inactive zone, or am I misunderstanding?Oh, and this is when I closed the bypass on a recent load, which went to glowing cat within 15-20 seconds. The second thermo is surface of single wall pipe about 15” above stove collar.
That position in cat probe should be about 100-200F, but glowing cat is probably close to 1000F.
View attachment 334715View attachment 334716View attachment 334717View attachment 334718View attachment 334719
I deliberately went with the 2R. I frequently take it into the woods, where space is really at premium, and the 3R was just too much tractor for that, besides the cost. Even the 2R is a heavy beast, evident by ruts left in wet lawn (which I will have to fill in the spring).I test-drove your 2038R before buying, and really liked it a lot. The ergonomics and visibility of the 2R series is much better than the 3R series, it's a much nicer machine for daily chores and climbing on/off.
Yep, and cat was glowing within 20 seconds. I do this on every cold start, and cat is usually glowing within 10 - 30 seconds. If it fails to take off after 30 seconds, I just go back to bypass for a few minutes more, and try again.You closed your bypass with the gauge that far in the inactive zone, or am I misunderstanding?
Yeah, the 2R is probably way better in the woods, the 3R just feels too "tippy" side to side. I had a 750 and then an 855, and like those, the 2R just "feels" well-planted. I was much more confident in side-to-side stability on the 2R, than I am on the 3R.I deliberately went with the 2R. I frequently take it into the woods, where space is really at premium, and the 3R was just too much tractor for that, besides the cost.
Yeah, I noticed the same! Some of the areas through which I need to haul my firewood can be wet and soft, so I was pretty sensitive to this when shopping tractors.Even the 2R is a heavy beast, evident by ruts left in wet lawn (which I will have to fill in the spring).
I do the same.You closed your bypass with the gauge that far in the inactive zone, or am I misunderstanding?
