Corona Virus
Thats the perfect cover story. You can bet the generals who do war game scenarios are looking closely at this. Flights going out had to be shut down from outside ,they should have done that ,unless they wanted it to spread.
Possibly, but I do not subscribe to that outfield theory. The history of the wet market is something you really should research, dates back to a famine stituation in China not all that long ago. China is not the only place of wet markets-by their very nature they are a breeding ground for trouble,health wise- and then there is the marketing ploys as well compounding the underlying issues.
Reactions: Seasoned Oak
Begreen, as I said I have family in health care in fact my daughter works in a Pediatric ICU and will be working with children sick with this virus. They've already implemented very stringent protocols for double gloving and double gowning, and then another protocol for removing those items. Another problem they are running into is a shortage of ICU containment suites, and this is at one of the largest if not the largest hospital in Michigan. They are working around the clock to add more. My wife in a Nurse Anesthetist, so will probably not be exposed at the same level as my daughter, but has had a surgery that left her with a diminished capacity to clear secretions. Her immune system is fine. I would be very interested in showing her the link or links where you got that information from. Thanks in advance!
Please thank her and your family for the work they do. It is so important.
That was not my first thought ,but their strange response is what makes me question motives. That coupled with now even denying it came from china at all ,plus now going as far as to be blaming the US military is really bizarre.
Reactions: Ashful
One should not confuse a dis-information and conspiracy war with the real medical war that is happening. There is good science coming out from China to other countries in spite of the friction barrier that has been raised here. Just yesterday it was reported that a research team in China has been studying cases after recovery. They found that surprisingly the Covid-19 virus was still alive in the upper respiratory tracts of some people 37 days after recovery! This is important information. We have a lot to learn still. Hostile rhetoric and disinformation help no one.
Reactions: Ashful
Your right,this information and hostile rhetoric came from a chinese newspaper ,and yes i did read they are just now starting to cooperate after the horse has left the barn.
Sounds like their equivalent of our politicos. It's rhetoric. They have pride too and don't like to lose face.
Our sewer department has what's called a bar screen that catches the lions share of all trash that is flushed. It catches it and a auger drives it out to a compactor and spits it out into a waste can. Of course some fine debris makes it through but it catches a lot of it. The big problem is old clay and transite lines that crack easily and tree roots infiltrate and then these wipes, diapers, ramen noodle packages you name it.....get caught and compound the problem. I work for a water and street department in my town but we help the sewer department often and we see this a lot.
My city has many lift stations that pump sewage towards the treatment plant. Sure, we have a screen at the plant that collects all kinds of interesting stuff but the problem with “flushable” wipes is that they wind around the shafts of the pumps at the lift stations and stop them. Constant maintenance.
Cutting up old clothes, sheets, or using other paper products is fine but just don’t flush them. Garbage can.
I'll dip my toe into the water here, and just say that some of the most valuable information on the virus could be coming from China and Italy which was hit extremely hard. I do not believe any information coming out of China, as they have a poor record on almost every front, whether it's intellectual property rights, human rights, and complete government control of what news leaves China. Italy on the other hand has been very helpful and I found this Dr. to be very frank and on the mark, as someone who it dealing with this daily.
So why are they double gloving and double gowning which are both directly against CDC recommendations. This is droplet protections. The requirements for that are only a mask on the pt if they tolerate it then gown and gloves. The provider may wear a mask but, until it is aerosolized through high flow oxygen or intubation there is no need for a hepa mask.
We have ceased field intubation of pt that we suspect. You wife is very much at risk unless All ever uses is video To intubate.
Reactions: Ashful
Look up a Muffin Monster and Channel Monster they work quite well for rags, strings and other items that should not be in the sewers to be being with. I used use them for industrial purposes.
They use that protocol during intubation and that's when they use a video largynoscope .
I can't help but believe that reports of sewer/septic problems from wipes stem from the use of the non-flushable biodegradable type which I think are synthetic, basically plastic.
We've been using the biodegradable type at our house on septic for 20 years without issue. I've watched the septic tank be pumped twice and the tech never mentioned any issues with wipes. It was clear from the content that whatever we were flushing was breaking down.
Maybe some that claim to be flushable aren't really biodegradable.
I hear ya. If the auger breaks down on ours it is a heck of a mess...and does happen. I wasnt implying to not worry about it and flush whatever your heart desires. I was just stating that most times blockages that I have seen start where there is a problem in the pipe already. Old infrastructure. Obviously flushing wipes that won't dissolve multiplies the problem.
Reactions: Highbeam
The death rate is about the same as the Spanish Flu so there is reason for concern. It's very contagious, but at least it is nothing like Ebola which was 50%! Thank goodness we reacted quickly then. The main concern is that politics will get in the way of quickly protecting Americans. This already appears to be happening. We need the CDC firing on all cylinders right now.
Until everyone is being tested on a daily frequency we will never know the true death rate. Here the only people being tested, as with most areas, are those that need hospital admission and meet the CDCs requirement for testing. If they test positive, no one they have been in contact is being tested at this time. There would be a possibility of an additional 2-3 at a minimum if the tested person was the original carrier for the cluster of infections. If not they were one they was infected by one of the 2-3 that was infected by the original carrier.
See the problem with trying to have any numbers? I confidently, based on my experience of providing medical care in different third world countries, expect that the infection number is exponentially higher and death rate considerably lower.
Reactions: begreen
Nope.
We raised 3 kids in this house from when it was new in 1996. Moved in when our oldest turned 1. Used wipes with all three, and I made sure the only ones that came here from the store were the 'right' ones. Got our tank pumped 5 years ago, there was a layer of the damned things all over the bottom that all looked like the day they were flushed. The pumper guy told me they just don't degrade and he sees it all the time. So unless they have somehow gotten better at making them degrade since we stopped using them, they just don't.
Reactions: Ashful
More on Italy's front line
The 18 school districts in our County have decided to close schools immediately until at least April 20th.
Our Governor closed every school in the state (Michigan) for 3 weeks and banned any gathering of 250 or more, which means most churches will be closed tomorrow. I'm not sure she has the authority to ban gatherings over 250 persons, but given the circumstances it is probably a wise choice.
Our governor made the same decision. It's necessary to reduce overload on the hospital system. This is a recent episode on local radio station about the Seattle frontline on the importance of flattening the curve.
The best way to go without TP is to squat, there is less cleanup, but still something remains. After living without a functional toilet for two years, you get creative. We made a simple composting toilet and started a compost pit and I prefer it to the regular toilet I'm sitting on now. When we remodel the bathroom it will probably get a bidet and a stool or something to facilitate squatting over the toilet. When I was in Afghanistan the local nationals used the toilet seat as a "perch" to squat over the toilets when on American compounds. I wish my wife would go for the Italian style public toilet that is little more than a flushable porcelain hole in the floor, but it's a bit too austere for her.
[/QU
I rented an apartment in China. It had a tiled shower room. The drain for the shower was also the toilet. You did not want to drop the soap. It would easily shoot down the hole. After using the washing machine, you threw the drain hose on the floor and it went down the toilet hole.
One village I was in had a mud hut community outhouse. When you entered, a little old man would run around the back of the building and put what looked like a bread pan under the hole. When you finished, he would run out and dump it on the crops. You went nowhere without packing your own TP.
TP in Korea in the early 70's resembled our crepe paper. Any TP not under lock and key was pirated. The natives would also use the seat as a perch, and we had a heck of a time keeping them from doing their laundry in the crapper.
We are spoiled. If you take a regular spade and cut the handle off about two feet long, stuck in the ground beside you it makes a great TP holder. If you are discrete, your neighbors may think you are planting flowers.
Reactions: SpaceBus
There was a woman on CNN last night with a UAB backdrop.
The question, paraphrasing: "The supermarket is out of alcohol sanitizers. Can I use a plant-based product?"
She actually said something like "FDA really has nothing to do with products like these" in her reply.
Really? FDA has responsibility for AB washes, surgical scrubs, etc. I was working on it in the 1990s. EPA has responsibility for hard-surface products. We had those, too.
My daughter was in India 7yrs ago. On a mission trip to help build - an outhouse. One concrete bunker add on for a family that needed it. Pit type, no seat, and only water to clean up.
This was a good movie, and gave some insight into that issue, and other poverty and toilet-related issues in India:
I'd like to know more about this if you have a reference or just additional info.
My recall is sketchy and probably based on some PBS TV show (maybe NOVA) some years ago.
If you'd rather not diverge here a PM would be great.
Got a project due for work this weekend, so I'll get back to you on this, after I've had a chance to review. But I believe you were substituting multistage rocket theory, which was already well-proven and being used by the Russians (in both parallel and sequential forms) in the 1960's, with the concept of space rendezvous as a plan for getting to the moon. This rendezvous concept was indeed challenged for some time, and there became three separate camps of thought, as to the best plan for a moon shot.
On the multistage rocket concept, Russians started with a really cool multistage plan in the 1950's, where all stages would initially fire in parallel (hence the name, "parallel multistage"), but stages would drop off as they progressed away from the earth. This was very efficient, but also more complicated and prone to fail. They eventually dropped back to the simpler sequential multistage with which we're all familiar, which we also used in the US.
Thread Derail, RE Baby Wipes and other wet wipes, in case others do not know, are a major issue with septic systems and plumbing in general. Within a few years I expect every house is going to end up with a macerator system required on the sewer outlet.
Before reading this thread, I would have never even considered that anyone would flush those things down a toilet! We went thru the baby wipes years (with babies... not the adults), starting in a house with public sewer and then moving to a house with septic, but in both cases we threw those things into a lidded trash can! The lid was mostly about keeping the dog out of them. ;sick
Depends on the city. Out local Plants debris catchment system handle these along with all the other debris and landfills it. Some cities cant seem to so anything right including potable water that safe for the public. Wipes are not going away so they had better learn how to deal with them. Its not rocket science.
True, but keep in mind the mentions above of Philadelphia and London, two of the oldest sewer systems in the world, and each of which handle more sewage per day than any smaller borough does in three or four months! Both likely have many aged or antique components spanning ~150 sq.mi. each, serving easily 10 million people per day (6-8 million residents + commuters), both systems being over 200 years old. Most of the largest towns in your "eastern central PA" are literally only 1/100th the population of these two massive old cities, and most haven't had sewer systems more than 60 years!
Off topic: Remember the Fat Berg in the London sewer a few years ago. Major yuk!
Yep. For anyone who missed it: https://www.npr.org/sections/thetwo...rg-london-s-130-ton-rock-solid-sewer-blockage
...we all need to show some form of restraint to reduce chaos within the hospital.
One of the key points of many of the interviews I've seen, including (if I recall) the Rogan interview begreen posted two pages back, is that this is the primary concern and motive behind event closings. Simply put, most of us are going to get this thing, and most of us will do fine with it. Many may have already had it, and not even realized it was anything other than a regular cold or flu. But for those who suffer more acutely from it and require hospital care, they are trying to avoid the same scenario we've all seen in Italy over the past ten days, in which so many people were infected so quickly that the hospitals are unable to handle the load. By closing schools and events, they are not under any assumption this will stop the spread, they are only trying to slow it to a rate at which our healthcare system is not loaded to the breaking point.
Trump of course has other motives, protecting the economy. Simply put, his re-election hinges on this one the economy doing well going into November. It almost appears that he hoped that by pretending corona was not an issue, it might go away. I guess for those who have lived thru the last dozen forecast "pandemics" that turned out to be non-events, with regard to the economy on a 6-month time scale, it was a calculated risk. Once the market tanked as a reaction to what was happening, it forced his hand toward a reaction. The rally on Friday, which I believe is an all-time record, was soothing for anyone who lost big money on Thursday. But I'm sure there's plenty of volatility in our near future, hang on to your hat.
I heard the same from one doctor, who prior to the interview was being touted as an expert of some kind in this field. But then I heard conflicting statements from two others, all within the same week. So those of us not in the industry, and apparently many who ARE in the industry, are left wondering. Was one doc apparently wrong, and the others right, or is this just an issue of timing and new observations?
...or they floated downstream into your field or mound, where they'll ruin your day sometime in the future? I dunno, just thinking out load.
