rideau
That sounds like the cat clogging problem with stainless cat on the PH - seems to happen to a few with really tall chimneys/strong draft/no ashpan combination. The outside surface of the stainless cat gets covered with fly ash, blocking the openings, at least in part. No ceramic cat available for PH. Obvious attempts at solution with PH: add a damper, add as ash pan. Did your friend fit into this profile? Would be helpful to know. More info we can get to figure out for sure why some, but only a very few, people are having this cat clogging issue with fly ash.My neighbor called me and said her Princess got so hot one night a smoke detector starting going off at 2 AM. The cat probe dial was twisted around and the surface thermometer was beyond 900 with a wildfire raging in the box. This was all happening with the stat setting below "2". She turned it down all the way and the stove calmed down but she didn't; she was scared to leave the stove unattended.
The stat knob was stiff, resistant to turning. I took the cover off and lubed all the points where there was a wear area with gun oil, the stat knob turned MUCH easier afterwards. Also cleaned all the dust off the flapper. It seems to work fine now, no issues since then.
This is the same stove that originally came with the backwards-wound thermostat coil. And a stainless cat that plugged/wouldn't light off properly and was replaced with a ceramic. As good as it is, it has had some issues. I have not read on this forum of any of these issues with the King.
Thanks.
