Lol. Jeff t. If I had one on hand I would
So what was the dealer's conclusion besides saying the house felt warm? Is he going to provide any further assistance in solving your problem? Is he in contact with BKVP ?My dealer just stopped by. The first thing he said was it felt warm. The temperature in the house was 72, keep in mind that it is 30° outside. I then told him I was burning on high ( by high I mean 3) for 2 1/2 hours. The temperature of the stove top was 600°. The cat temp guage was about 3/4 past active. I dropped it down to 2 and the stove top dropped below 500° pretty quick. The cat guage dropped below half past active quickly. The next load I'm going to try cannons idea. I had to load it full for the dealer to look at. I'll try anything until the furnace kicks on. That's were I draw the line. I have a 4 month old baby boy that will not get cold on my watch. I did burn the kiln dried wood last night with no change. I loaded it at 11:30, dialed it down to 2 ( lower than to and everything drops), and woke up at 6 with ash and just a couple of coals. I'm trying to drop the thermostat but it will not heat my home. Sick to my stomach. I know these stoves are excellent. I just think there is something wrong that I'm not catching or find.
Is he going to help you solve the problem? What is he suggesting?He thinks there is a problem. He thinks these are still short burn times. He thought it was warm but didn't know I was burning so high to achieve inside temps.
Everyone on Hearth.com is so very helpful and they have a wealth of personal experience to share. But the real knowledge base of information about this stove lies with BK. Hopefully they will bring their resources to bear and solve this perplexing problem for you. This has got to be very stressful, but I am sure a solution will be found. Hang in there, and best of luck.Not sure yet.
How's this load doing Illinois?Rdust I am trying your method. I got her hot and shut her down. Here's a pic at 2:30(broken image removed)
The stove stalled out after 2 hours. Just had to turn it up a bit. The manometer tested at .03 positive. Now I have to figure out what that means. It's the high side of what I need I guess
I was looking at the pics you posted on page three of the stove and on the pics showing your stove the bypass lever was open on both pics, "when the lever points to you its opened, when its pointed away from you its in the closed position" I know those were pics of the stove before and after a reload but can you confirm that the lever is pointed away from you right now?
Yeah Illinois burner did a load with the stove hot and shut the stove down to see if he could maintain a prolonged cat light off and decent stove top temps.. Something is wrong here, That dented chimney section is only an outside dent right?What setting did you have it on? When you say stalled out do you mean the cat went "inactive"?
