Dieselhead
You know it's burning through wood too fast when your glass is that clear
I'm new on here. Not sure how to find Zanny.
Well said.....HANG IN THERE!
i was frustrated with my ashford when i first got mine. my smaller hearthstone was good but all the BK rave on here had me super excited to experience one- i was convinced it would be all peaches and cream... i could simply load it up and walk away for 24 hours when its frigid out and my house would be toasty warm! right? WRONG! it seems some get a BK setup and right away- BINGO! everything is perfect, and they are super happy. others- not so much, it takes a while to figure the set up out and work out the kinks. everyone says that "every setup is different". they couldnt be more right. also, each house is different. no matter how well you THINK your house is air sealed and insulated, some houses simply lose heat more than others. mine is one. although its a new construction, it becomes very tough to keep warm when the breeze picks up. i will continue to work to tighten things up. not only is it leaky, but i sit on a hill where the wind simply howls. when its 20 out and blowing 25 i am simply asking too much out of the stove. my chimney drafts like crazy when its like that, it literally sounds like a jet engine. my burn times were super short, even making it overnight on a low setting was tough. i finally found out what makes a HUGE difference in my burn times. the blower. having it on literally cuts my burn times in half. last night i loaded it fairly light, went to bed at 10 fans off and set at 1.75. at 7 am, there was a remarkable amount of fuel left in there. i am now going to simply run it as a radiant heater for a while and see how it heats the house. again, still working, still learning. and i bought my stove last january. am i 100% satisfied with it? i guess i would say no at this point- but i think my expectations were simply too high. however, my satisfaction is increasing daily as i learn more.
you have bought a quality product from a company who backs it up. it may take some more effort, but it will get figured out. work with chris (BKVP) directly if your dealer is not doing their job. use the PM feature on here to contact him directly and start a dialogue offline. his accessability is one of the reasons i bought this stove. i even noticed he was responding to threads on here on thanksgiving.... that tells me alot about him. he does not want anyone unhappy with their product.
type in "zanimal" in the search under member names. his similar problems were located in the 13/14 BK thread.
Why not drill a hole in the pipe and put a probe thermometer in? Than you'll know the stack temperature.I'm tempted to put my single wall stove pipe back in so I can monitor the flue temp better
For what it's worth, a neighbor of mine has a poor draft problem with his BK stove due to a less then optimum chimney setup, but his problem is the opposite of yours. He can't get a raging fire and he gets a nasty smoke smell in the house at times. He believes his stove is OK because he used it at another location and it performed well.I put another 4 feet of pipe on today giving me at total of 19 feet outside. It looks ridiculous. I just loaded it with the wood I have at 3:45. The next load will be the kiln dried wood. Hopefully I see a dramatic change
I may be getting a little more heat but it's hard to judge with the outside temperature almost 20° warmer.After 2 1/2 hours on high. I'm sitting 4 feet away from it. It definitely hasn't chases me out of the room yet
(broken image removed)some wood tests(broken image removed)(broken image removed)(broken image removed)coalbed(broken image removed)before loading (broken image removed)(broken image removed)ten minutes in(broken image removed)20 minutes in(broken image removed)20 minutes in (broken image removed)20 minutes in (broken image removed)45 minutes in(broken image removed)45 minutes in (broken image removed)45 minutes in
