BKVP
Leaving Fairbanks Monday...off to KOP PA next week....Actually, if he's going to be in town, he offers to buy for anyone interested!
The ash plug may not line up with the ash drawer.Bumping this thread. Got my Ashford 30 installed today. Little susprised by the manufactured date of March 2015. Anything I should be concerned about from the units that were produced around this time?
That’s not uncommon at all. Stoves get shipped from a distributors warehouse to a retailers warehouse, sometimes certain stoves move a little slower.Bumping this thread. Got my Ashford 30 installed today. Little susprised by the manufactured date of March 2015. Anything I should be concerned about from the units that were produced around this time?
There was a very small production run a few years back that had some misalignment with the ash pan, just make sure the plug is over the pan.
My memory is not perfect, but I believe there was only ever one of those cases attributed to a bad weld. If I recall, there were 10-12 cases, and each was resolved differently. The most common fix, if one could be called out, was a high-density door gasket.Thanks, I’ll check that. In terms of the smoke issue that some folks had, should I be checking any potential problematic welds or something else?
Hard to believe any stench could be exiting the stove with that much draft.Straight 32’ chimney with 2/3 of it indoors and approx 9 feet outside (a couple feet in corner of attic crawl space) great draft.
That's a bummer. Have you been able to pinpoint where the smell is coming from?I had my Ashford 30 installed December 2017. Straight 32’ chimney with 2/3 of it indoors and approx 9 feet outside (a couple feet in corner of attic crawl space) great draft. Class A double wall pipe with no OAK. Did my research and worked with the only Blaze King accredited dealer in my area. I put about 3 cords of seasoned wood <=20% MC through it, essentially burned one continuous fire throughout the winter (NorthEast). Stove sits in a 2 story room in a relatively new house and I have “THE SMELL”. I ignored it for the most part last year, but decided to inquire and discovered that this is a common issue with BK. I contacted them as well as the installer and just last week had the larger door gasket installed. Sadly, it doesn’t really seem to make a difference. Sort of out of ideas. One question that I don’t believe that has been brought up is whether or not the smoldering creosote/smoke smell is hazardous. I’ve got some young lungs in the house.
If I remember correctly, a member here with tall chimney was having the same issues due to too much draft. And when burning low is like the excess of draf pull the intake air to quick. I think he installed a key damper and that took care the issue. Maybe somebody else remember more the details or the member that had the issue.
Right, he put forth a well-reasoned theory that turbulence in the box from high draft may have caused smoke to escape...now who the heck was that?? Someone who's not a real prolific poster, that I remember..If I remember correctly, a member here with tall chimney was having the same issues due to too much draft. And when burning low is like the excess of draf pull the intake air to quick. I think he installed a key damper and that took care the issue. Maybe somebody else remember more the details or the member that had the issue.
Here’s one just for the Ashford 30 crowd, how do you perform or judge the result of your dollar bill tests, with the door casting inset into the surrounding casting?
I dont think the dollar bill test works good on a knife edge door. I just look for a good indentation in the gasket and re-fluff the gasket if i think it needs it ...
I remember this one. He was a west coast guy, California I think. He had a brown enamel Ashford. He and I were having the same issue at the same time.If I remember correctly, a member here with tall chimney was having the same issues due to too much draft. And when burning low is like the excess of draf pull the intake air to quick. I think he installed a key damper and that took care the issue. Maybe somebody else remember more the details or the member that had the issue.
