ratsrepus
When I had the smell i actually liked it
Sent from my SM-G930W8 using Tapatalk
Used to feel that way about my old girlfriend
I did mine cold and removed the top and sides, not ideal but helped straighten the path a bit.Here’s one just for the Ashford 30 crowd, how do you perform or judge the result of your dollar bill tests, with the door casting inset into the surrounding casting? Mine feels good, but I’m not sure how much of the resistance I feel is due to gasket vs casting overlap. My latch force is definitely a lot lower on one stove than the other, and they’re both way lower than they were when new, but both stoves still prevent me from pulling a dollar thru interface between door and stove body.
Yes, front left if you’re facing the stove. Towards the top. The installer removed the top & sides and no pinholes in the welding.That's a bummer. Have you been able to pinpoint where the smell is coming from?
Prior to having the new “gasket kit”—the one that’s supposed to remedy the smoke smell issue—installed, my door did NOT pass the dollar bill test on the latch (right) side. It was tight on the top & bottom, however.Here’s one just for the Ashford 30 crowd, how do you perform or judge the result of your dollar bill tests, with the door casting inset into the surrounding casting? Mine feels good, but I’m not sure how much of the resistance I feel is due to gasket vs casting overlap. My latch force is definitely a lot lower on one stove than the other, and they’re both way lower than they were when new, but both stoves still prevent me from pulling a dollar thru interface between door and stove body.
Some of you may remember I had trouble with my old Ashford and spent quite a bit of time and money getting a better draft, changing bolts under the gasket, trying different gaskets, etc. to try to get rid of the smell. Well, I now have a new Ashford in my new home and have the same issue, this time, draft is NOT the issue.
I think I have it at least narrowed down to the hinge on the door. I have read that other BK owners also complain of the smell coming from the left front. With the top off, I can really isolate exactly where it’s emitting from laterally and it’s different than with the top on, obviously. As it rises up, it gets pulled in whatever direction and can lead us to believe its coming from elsewhere. With the top off, it’s right over the hinge and nowhere else. As the fire burns back and away from that area, the smell goes away.
Another interesting new observation on this brand new stove is that after my first few warm up fires, I was giving the stove a once over and noticed the door, when latched, could be pressed upon and there was give indicating that the latch was not that tight. So, l tightened it very slightly which brought the latch to a more secure feel. No play when pressing on the door. Would you guess that the smell got worse!? My theory is that since the latch pulled the door more tightly closed on the latch side, it exasperates the issue with the hinge, bowing it further out from the knife edge causing the release of the smell.
I just wanted to let everyone know my experience. I obviously love the stove enough to rebuy it, but God I hate this smell. My new neighbor actually loves the stove and is in the market but he can smell it so is turned off. If anyone has a fix that isn’t the same old draft argument, Id be very grateful. My new setup is as follows: 25’ straight up, double wall, OAK, no fan kit, yet. I burn everything from cedar to white oak, MC 15-18% with most everything, sometimes lower. I burn every load for at least 10mins before I engage the cat, sometimes longer if my chimney isn’t getting too hot. House is 2200sf. Stay warm everyone!
Generally speaking, I would expect that a wood stove with the door closed would be at a negative pressure with respect to the air the stove is sitting in. So any leak would draw air into the stove, and prevent combustion gasses inside the stove from getting out.
So I would expect a negative pressure in the stove and no leaking. An odor from the stove into the surrounding air suggest a positive pressure inside the stove.
...after reading all nine pages of this thread and seeing how Blaze King takes care of their customers, I would run a BK in a cocaine heartbeat...
This is exactly why I'm also a big fan of Woodstock. Both of these companies are at the top of the heap, in terms of technology, product quality, and customer support.As an unabashed Woodstock fanboy, I can say that after reading all nine pages of this thread and seeing how Blaze King takes care of their customers, I would run a BK in a cocaine heartbeat. No company has ever released only perfect products - what separates the men from the boys is how they step up to make things right when they start off wrong.
You have a good handle on the static pressure situation, but surprising things can happen when it’s all put into motion. Think of a Venturi vacuum pump, and how it can create vacuum from the application of positive air pressure. It has been theorized that the air wash system, which is more effective or aggressive in the Ashford than in the Princess or King, might provide a localized high pressure at the door gasket.
This seems unlikely, given the large open volume of the firebox, but so far it is the theory that’s hardest to refute in my mind.
Very interesting! The high draft smoke smell is not as big of a concern for me since I rarely need to operate the stove at this temperature, but I can see where it would be a concern for people who frequently need to run their stove really hot. I also do not have a fan kit and I realize most people do, so this may change my experience relative to others as well. I'm just happy the high density gasket and the copper silicone took care of nearly all the smell on low burns, and that meant the world to me!Hi all that was me with the high draft smoke smell issue. My theory was that the excess draft was creating a larger pressure differential at the air wash angle. Instead of the air rolling down the glass nicely, creating s boundary between the smoke and glass the air was being pulled directly off the wedge back to the cat, due to the higher then normal vacuum created by the flu.
Another contributing factor may be that when laminar flow air is pulled away it can get very turbulent pounding against then glass pushing smoke out past the gasket.
Sent from my iPhone using Tapatalk Pro
I thought you were referring to the damper setting, but in this house with the taller stack I have the higher draft variable at play as well. Your theory certainly makes sense to me! At any rate, Im a happy man with a nice drafting stove and practically no smoke smell. Gotta save up for a fan kit now and put away this ugly box fan.Ya I was referring to low heat damper settings. The lower the heat setting the more shut the damper which increases creates the greatest pressure drop inside the box. Remember the damper is before the stove, the chimney is on the other side and the airwash is in the middle.
The only smoke smell I have is on low and it’s barely detectable, but made worse by having wood close to the loading door.
In a aircraft a wing stalls at a certain angle of attack to the oncoming air, the air wash is a wing in which is job is only to smoothly move the air on to the glass. Suck to hard against it and the air wash “stalls” and air goes directly off the wash straight for the cat.
Who the hell knows, it’s the best I can come up with. BK is a great stove and keep in mind no other stove goes into turn down mode as far as a Bk and it’s only in turndown mode that a few of these things smell. I mean we are slow cooking creosote black oozy stuff inside the box. Step up a bit and it’s gone...
Yep, Bk sent me a new style gasket and some copper silicone. Fixed me right up!@Calentarse, can you save me some back reading, and remind me what the fix was for your situation? I remember yours being persistent.
