Agreed, although I do suspect I was cited as one of your exceptions.
However, if we're going to talk about running on high, the Ashford has a fatal flaw that may not be shared with the King or Princess: the cats seem to clog with ash when the stove is run on higher settings.
Perhaps I was unable to get the combustor fully vacuumed 100% clean (internally) the first time it clogged, although it certainly looked clean from the surface I could view, or perhaps it was actually clean and has completely clogged a second time in a month. I don't know yet, but I have watched my fire go from raging to almost instantly dead the last two nights, when closing my bypass damper on a well-charred load. That has only happened with a plugged cat, in the past. I let the stove go cold today, so I can investigate (again) tonight.
My second Ashford (yes, I have two) always runs at a lower setting, and has not experienced this problem after two seasons of 24/7 operation. Same stove, same install date, same wood, same house, same operator... so it comes down to differences in burn rate and chimney height, as to why one clogs and the other does not.
