So the pics show the tighter braid to the fiberglass rope gasket than what came new with the unit. I don't have the original mfg of the gasket material but I will get it Monday when the dealer is open. It appears to be a higher quality rope as its more costly to mfg the tighter braids.
But it's pretty obvious from the pic showing the key by the firebox opening and the casting the issue BK is having with getting enough clearance between the two in order to get a wider gasket retainer to work. If they used the same size one as used on the classic stoves I think it would be a better design but that means changing the molds for the casting, which would be costly.
Also with this stove it's important to note its design puts the logs closer to the door than other classic series and that means the rope gasket has a more demanding job right out of the gate.
Let's see how well this lasts but as of now we're going on day 2 of no smoke smell at any setting! Thanks for all the help everyone.
