When you replaced the gasket did you remove the door? If so, how hard was it to remove?I laid about a 3/8" bead all the way around...
Even though the smoke smell never bothered me and I don't have the issue anymore, I really hope the fix is really as simple as a really good gasket installation![]()
Did the dealer remove the door to replace the gasket? I can't wait to hear about the results tomorrowUpdate. Just had the gasket replaced. The original just had dabs of RTV here and there. The RTV was applied in a fat ~3/8" continuous bead. The whole channel had RTV in it with some squishing up both sides and out. I will fire the stove 24 Hrs from now and give another update. He used red hi temp RTV.
Ok. Thanks. What made you decide to have the dealer do it? If this works for you I'm going to do the same thing.The door remained in place during the installation of the gasket. The door is latched during the drying process. The gasket replacement was easy to do. I used a vacuum cleaner to suck up the airborn fiberglass frizzes during the installation. A little dab of RTV was placed at the end joint
I have talked to him on here. He is going to send me the gasket. I just don't know if I want to try it myself. I have never done one before and this is my first stove. I would rather have a dealer do it but I don't really care for my dealer. I had the stove installed in July of this year.If you call Chris at BK, he will probably send you a gasket since you are having the "smoke smell" problem too.
Thanks for explaining all that for me.The device I used to measure the draft is called a Magnehelic. It is use to measure faint pressures. The one I used goes from zero to .25" water column. You can get one from WW Grainger online but I don't think it will be necessary. It is ~$60.00. You will also need barb fittings and a rubber hose to connect it to the stove or flue. I jammed a volley ball inflation needle into the end of the hose to sense the stove pressure at the cat thermometer hole as this is a direct access to the fireside of the stove. If you have a flue thermometer, you could remove it and use that hole too. It will read slightly lower than the cat hole as it is higher on the flue. I used to work in HVAC and used it to check ducts, boiler operation etc.
It is the total height and the diameter (if kept reasonable) that determine the draw at medium and low flow rates. The bends you have (2-45s) won't have any effect on draw except at high flow rates. At high flow rates the chimney will be much hotter which will in turn negate any restrictive effect they may impart on flow. At 17' I think you are in great shape draw wise.
That's craziness and sounds like a good way to glue your door shut! I've always been told to install the gasket on the bench and let it cure on the bench. Install after cure.
If I tried this with the door on I'd have had red RTV all over the place.
I have to paint everything white. No biggie.Anyone ever take an ashford door off?
How hard was it? What's all involved?I have to paint everything white. No biggie.
Thanks. If I gotta change gasket I would rather the door be off.
- Stove off, lift off top. Set aside.
- Back out bolts just a tad holding the sides to the track they lay in.
- Lift sides straight up and set aside.
- Now that sides are removed, look around behind the door frame. The are four big nuts/bolts holding the iron face on the steel inner stove. Back them off
- Unlatch the door and remove face.
- Done. Prob. take you about 12 minutes.
i've re-gasketed many, many doors, I always close the door so the sealant dries in the proper shape.
in 18yrs never any complaints
