Ashford 30.1 smoke smell
I've seen the copper RTV for auto exhaust systems rated at 800 intermittent.
What's the flat wrap? Haven't heard this term.
That is my experience as well. Almost burn my nose to check for the smell and I can find it but otherwise nobody says anything. It's like checking the dog's butthole for dog farts. If you get right up on that dog's butthole it probably has a smell even if the dog hasn't farted.
I can't stop laughin!
How I missed that I don't know, now I got it. My BK doesn't have that.
The other thread trying to nail down possible cures for Ashford smoke coming from the hinge area is closed, so I will continue here. Currently, I am working with my stove vendor, Dave at A-1 Stoves in Grass Valley, Ca. Dave will be getting with Chris at BK and then he will get back to me as to possible resolves on Monday. In reading various threads, replacing the bolts on the window frame clamp with button head bolts and increasing the flue height have been fixes for some units. My gasket looks good. New stove with 5 days on it. 18' of straight chimny. The draw =-.05" @ 300F. Any other possible fixes I missed?
Thanks for the update.
Has anyone else tried putting the silicone around the outside of the gasket channel with any luck?
This stuff is rated to 2000 deg:
I saw some silicone at the stove shop
that was 1100, I think. I've heard Mill-pac mentioned here also...
Just be careful. Some RTV sets up like stone under high heat. It can be very hard to remove once baked. This doesn't seem to be the case with all RTVs, but you might want to do a test before committing to a new product or use what the stove mfg. recommends.
Just plain old black silicone is what's being used on door gaskets. It'll hold up very well. But if it's not protected from direct flames then It's toast! It must be behind the gasket, not out in the open.
Not yet, but I will post as soon as I get any information. So far fixes have been: 1. Increasing the flue height. This does not always work and is costly. Mine is 18' and the draw pressure is within spec. 2. Replacing the window fasteners with ones that don't protrude as much and then regasketing. My stove, being newer, has the button head bolts. 3. Sealing under the gasket with silicone. I don't know if this is a permanent solution because of the heat involved. It does give credence to the "door air wash blowing smoke under the gasket" theory. Did I miss any fixes?
Yes, as I suspected, it burned to ash and crumbled off. It was rated to 800F.
Yeah, it's similar to the Buck, judging from blueguy's pic on page 3. Obviously the gasket has to hit around the outside of the hole in front of the stove, so the gasket and door frame are protected from direct flame/radiation by the front of the stove. I never saw silicone "burned to ash and crumbled off." Maybe you had bad cement or silicone, if yours crumbled out?
"Sealing under the gasket with silicone." ?? Isn't there a continuous bead of adhesive all the way around, under the gasket? That's what I normally see, with silicone or cement. As I said, the silicone should hold up.
I just had a conversation with Chris (BKVP) about the smoke smell issue. I conducted some tests and determined that it is possible to have smoke move sideways through the gasket. This strongly supports the "air wash blowing smoke through the gasket" theory. Still only theory at this time, but time will tell. Chris is going to provide me with a more dense gasket in an attempt to stop the lateral movement of smoke. A word of caution - do not remove the door to work on it as it is quite difficult to reattach in good alignment. Hold off on using silicone compounds, the long term effect on the cat is unknown.
Hmmm-I just had a real cool conversation with the VP! These people really do care about us end users.
Good to hear. I'm sad to say I believe I'm experiencing the same issue, same smoke smell just above the top door hinge. Thanks for the updates, keep us posted.
Great to hear. Hopefully this will solve the issue. I might have to do the same thing. Are you doing it yourself or having your dealer do the work?
What tests did you do?
How does the door mount? The doors I've seen (limited number) have all had hinges...nothing to mis-align.
If silicone hurt cats, why are BK and other makers using it on their cat stoves? I would think once it dries, any additional off-gassing would be infinitesimal. But what do I know...
Reactions: webby3650
It seems like this stove needs a lot of draft to contain the smoke. If you have a marginal chimney, or live in CA where average daily temps never get below 50, you may have to choose in the end weather to add stack, live with the smell (which I do with the Dutchwest since I haven't bothered to track it down yet,) or get a stove that breathes easier.
Out of the many thousands of these stoves that are sold only a very few have this "smoke smell" problem. Magnehelic readings indicate the chimney is not the culprit. Just a matter of time and we will have this issue resolved. It will be something simple but elusive. I am working directly with the BKVP on this. How cool is that?! I worked in HVAC for many years and feel very confident about a forthcoming fix.
