woodstove guy
I am packing the box full of wood. And by full I mean the andirons were removed and the wood is up to the glass. I was told by the tech that this is acceptable and will do no harm so long as you don't slam the door against a protruding log.
I was told today by my dealer that the coal bed is considered "burn time" by the manufacturer. Well, ok. But it's not kicking out any heat so in my book I think that's a load of bs.
The plate should be in tomorrow or fri. When I get it I hope it's an easy install and it's the solution to the problem. The consensus is that it will be.
I understand that you were able to get the fire going with the coals. That's all well and good but was it still throwing out heat? Starting up a fire is not an issue for me. It's the ability of the stove to heat for a set period of time that I'm not happy with. The literature is misleading in making me believe that this stove would heat the house for up to 14hrs. Not just a few hours of intense heat followed by a very long smoldering ash pile that doesn't give off any appreciable heat.
Johnny for what its worth by all accounts I was looking for something the insert isn't designed for. Its tough to get your head around expecting the same fire and fire effect you get from one of the non-cats was a mistake. I bought this one for longer burns knowing that my shift-work meant I have to be away for anywhere up to fourteen to sixteen hours at a time. All I wanted to be sure of was being able to come home to heat and not have to go thru the pains of starting all over again with a cold insert. This insert is giving me that now. It also is flexible enough for me when I am home on the weekend and just want it to burn like the non cat did. I just go thru more wood, that's all. But when I want the overnight, it works well. I really did have to understand it a bit better. Like I said, I am still learning but making great progress.
Its on wood stove guy. My catalytic is usually around 1050 when I close it down for the day and seems to settle to around 800 after an hour or so. Don't take this as a guarantee as I have spoke to a few people at my local shop and some are higher and some are lower ,Jimmy the owner said to never engage it before 500 and just because it was 500 doesn't mean its ready to roll.I tried it once and closed it at 500 after it was running only about 20 mins or so and the cat dropped down to the word cool almost rite away. I am burning ash and oak splits on the larger side with mall splits that are wrist sized that I piece in between the others when im loading for long burns. Hopefully this helps I would be more than happy to try and answer any questions if I am able to for my fellow wood burning friends. Peace and Love Rocco
