griam01
Thank you, that is the perfect fire nice glowing cat I would say your 1000+.
Thanks I will definitely check the probe and see if I can adjust it.
Does the fan run past the cat? Is it possible for it to be taking heat away or is that what you mean that it may not be inserted correctly and that's why I see such a significant drop when I turn it on?
![[Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly? [Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly?](https://www.hearth.com/talk/data/attachments/187/187720-ffb9f9ee725529ee913f5cabcd095410.jpg?hash=122QkfP9gN)
![[Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly? [Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly?](https://www.hearth.com/talk/data/attachments/187/187721-486736bb72439554939ce8f3f4007923.jpg?hash=m2u_H_5RYy)
![[Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly? [Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly?](https://www.hearth.com/talk/data/attachments/187/187722-81d026dd8d0c7987e9f19e3e7aa45885.jpg?hash=_WdwYDYqNv)
If there's any way to see where the end of the probe is, it should be about 1/2" from the cat face.![[Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly? [Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly?](https://www.hearth.com/talk/data/attachments/187/187743-ce20f2cd67c73638a5da29785806ac7c.jpg?hash=RjjHcRpomi)
![[Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly? [Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly?](https://www.hearth.com/talk/data/attachments/187/187744-665a7c2ab1f793f1eafbd6c806573fcb.jpg?hash=ZivshNAKcd)
![[Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly? [Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly?](https://www.hearth.com/talk/data/attachments/187/187752-99248ac7916581e90d863a54f2db031d.jpg?hash=oqbvbUtguU)
![[Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly? [Hearth.com] Advice / Review need: Regency CI2600 fireplace insert risky & costly?](https://www.hearth.com/talk/data/attachments/187/187894-81941cd3cb8e2c6c6b61f6522f951ead.jpg?hash=XsvGNUegnl)
