I am not getting any sufficient burn times. Loaded it up to the point where no more wood would fit at 3:00. Went to the inlaws, back at 8:30. No fire. Thick bed of coals producing zero heat and thermostatically controlled fan was off.
I'm at my wits end with this fu**ing stove. I spent a lot of money on a heater which does anything but.
I bought this stove for these reasons, which the company touted;
Up to 14hrs burn time
Takes 20" logs
My results are nowhere near this claim. If the manufacturer tells me that a bed of coals which do nothing to supply heat is considered "burn time" then I will say go F**k yourself.
20" logs? sure. If you load only one way and then you cannot put enough wood in it to achieve any significant burn time.
Listen, I've got three kids under 3. I work 70+hrs a week and my wife does as well. I don't have time to fart around with this stove and be some kind of beta tester. I purchased this stove under the assumption that it would perform in a manner consistent with the manufacturers claims. This has not been the case at all.
I don't really know what my options are at this point. Ideally I would like the company to return my money. I don't see this stove working out at all.
Honestly I don't even know what options I have. Suggestions are welcome.
Takes 20" logs
