Question from reading Novembers posts. Stove is a VC Encore, wood is very seasoned (12%) and stored inside of dry building. Flue is 6" 27' with exceptional draft compared to wood stoves I've ran in the past with 16 'flue.
So we built new home and wanted wood stove in case of emergency, but also I like to work with firewood. Last season i figured out i had to get the fire going , then within 15 minutes shut air off as tight as possible to keep extra strong flue draft from overheating stove and especially catalyst ( no temperature reading, just going by white zone on dial in back of stove).
Cutting air off gave me smooth 4-5 hour burns that heated a 3000 sq ft home very comfortably (75 main room, 72 most of house). Problem was/is I would get some dark glass and very gentle puff backs as the hot fire was just a little too starved for oxygen IMO.
So, seeing cold air is headed to Ohio next week, I tried to open the air up a bit this morning. As the fire gained in heat, it eventually started puffing again, this time more forceably, I'm assuming because it was larger and more intense but still incapable of burning all the released gasses with the amount of oxygen im feeding it? This time the back fires have caused smoke into the room, thankfully Moms not home to appreciate my pyrotechnics on display.
So my primary questions are
1- is the cat really too hot when outside the white painted area?
2- am I burning it wrong starving it for air before just as the wood gets ignited well?
I weigh my wood, and burn 120lbs per day on an average 35 degree winter day. That equates to about 547,000 btu's actual heat if stove is converting at 80% efficiency. This number is almost exactly what it takes on a similar temperature day to heat with propane. Propane use is 6.4 gallons per day at 93% efficiency yielding the same 550,000 btu's.
So draft is based on how hot the stovepipe is and also outside temperature. So even though you have 27ft of stovepipe your draft will get stronger as the stovepipe heats up and weaker as it cools. Your backpuffing is from a buildup of gasses, the best thing to do is avoid that air setting and if it happens.. increase the air slightly
I would avoid the Bimetal probe.. get a albur at100.. digital probe and k type thermo coupler.. youll get exact readings and will be able to see in real-time whats happening.
Cutting the air back is the advantage of any cat stove.. so your not wrong in doing this.. you just need to learn to set the air to avoid the back puffing
