Well.... total train wreck last night. I do not know what you did to incite the wrath of Hestia but the curse has moved east..... This burn was one of the worst I have ever seen.
I followed my normal process, full load on a decent bed of coals I spread evenly. Only exception was I engaged the cat at 600 instead of 650, just to see if it would work. All seemed fine but it was not to be. I did notice that there was no flame visible through the glass, just an orange glow at the bottom.
At 21:40 I closed the key damper to kill draft, opened the griddle to take a peak and all the combustion was happening at the back of the stove, very smoky. Rather than leave the key damper closed I tried to save the burn by opening the damper, increasing air to move the fire to the front. When I saw flames in the front I closed the bypass and left air open, let it go for a bit and saw cat / flue temps peak then I closed down the air again and went back to bed. Flue gas hit 1350...... fortunately it came back down quickly.
At 23:20 we had round 2, at this hour I have no patience so I just messed with the draft, did not like what I saw so I closed the key damper, killed the air and went to bed.
For some reason this load decide to burn in the lower back corner, right at the secondary smoke inlet..... I am going to try raking coals to the front every time in the future to discourage this,
What a sh*tshow.... Looking for a small animal to sacrifice to regain favor of Hestia
