stoveliker
I do spread them out sometimes, especially if I want a full load in. Or I rake them to the front and take a bottom layer of splits that's 1-2" shorter. (That'll stop soon as I now cut my own rounds...)-I thought I had always seen BK users say “rake the coals to the front” on a reload. But I find if I rake them all to the front it makes it difficult to get a full load of wood in. If I rake them all to one side, spread evenly front to back, the stove both loads better, and burns more steady. Do others do this?
My stove is in the basement, so aesthetics are not that important for me.-for the summer, do many people open the bypass and crack the front door, in order to reduce gasket compression? Or is that not necessary? If I do that I’m going to have to seal my chimney somehow because the summer time reverse airflow stinks.
I take the telescoping section out, cap both open ends (on the stove and on the chimney), I open the bypass, but I keep the door closed. I also put a plug in the air inlet in the back.
This way I avoid reverse airflow (caps) and create a closed fire box. In there I put damprid in its quart-sized container, so I keep the stove dry on the inside.
Baby-ing my stove
![embarrassed ;em ;em](/talk/styles/default/xenforo/smileys/embarrassed.gif)
![shade smirk >> >>](/talk/styles/default/xenforo/smileys/shade_smirk.gif)
