BKVP
That sir is the truth!Yeah, but you you're not getting the chance to play Paul Bunyan, working off all those airline and hotel meals.![]()
Looking forward to the sunny cool weather.We’re just cooling back down after a bit of a warm spell.
Yes! I can’t figure out when to run it or burn wood instead. It’s super cheap to run. If it’s in the 30s, I’m burning wood for sure.Is that heat pump messing things up for you highbeam? I had to let the fire go out a few times during that warm spell but I’m lazy about adjusting the thermostat
Other than automatic turn-down overnight, I leave mine turned up to 70F. It's my game to stay ahead of it with the stoves, but should I fail, I don't have to hear complaints from my wife about it being cold.I had to let the fire go out a few times during that warm spell but I’m lazy about adjusting the thermostat
If you search this forum, you'll find a post or two from me that are almost identical to yours, ca. 2019.I put a steel cat in this fall and it has been working great until two weeks ago. I noticed when I close the bypass and turn the thermostat way up the fire is not an inferno like it should be. It is a lazy flame similar to what it should be when I place the thermostat in the 3:00 position. This isn't my first Rodeo, I suspected fly ash or a dirty chimney. I shut everything down, cleaned the chimney and dusted the cat. The cat appeared to have some fly ash on the front face. the rear of the cat appeared to be ok. I fired everything up at it operated as it should. Fast forward to this week, same problem, I shut everything down and dusted the cat again. This time the problem was not resolved. I can still get a decent burn but very little visible flames. Are steel cats more susceptible to fly ash? Can it get so plugged a dusting wont clean it? Any other suggestions? Yes, my Oak is dry and well seasoned. 12-15% moisture.
![[Hearth.com] 2022-2023 BK everything thread [Hearth.com] 2022-2023 BK everything thread](https://www.hearth.com/talk/data/attachments/308/308047-2ef43c8478d672240bb5841cd0e25e08.jpg?hash=_btkq_EHKW)
![[Hearth.com] 2022-2023 BK everything thread [Hearth.com] 2022-2023 BK everything thread](https://www.hearth.com/talk/data/attachments/308/308046-54b6025a90e312cccce881bae8506a5c.jpg?hash=OPfHgIilPs)
![[Hearth.com] 2022-2023 BK everything thread [Hearth.com] 2022-2023 BK everything thread](https://www.hearth.com/talk/data/attachments/308/308048-723f63420ca19c6aa44b21581af4132d.jpg?hash=XlhD79F4nw)
Ya, that low and slow heat output really shines with the heat pump until we get up into the high 40’s low 50’s and then it’s merciless. Always on the fence wether to turn the heat pump off or let the stove go out. 32 here now, perfect princess weather!
Interesting. I've always used nighttime lows as my decision to load. Given the dynamics of our house (~1 million pounds of stone), I should really go more by average daily temperature, but overnight lows below 50F is my usual trigger to load stove #1. If below 40F, I also load stove #2.I was considering daytime highs as my decision maker but these cat stoves burn for 24 hours and so I moved to nighttime lows as being the criteria. I light the princess in the evening after it gets dark when temps are forecast in the 30s (I like to be stealth about my burning) and so the initial pulse of heat happens after the heat of the day and sets me up for a long cruise trailing off in the heat of the next day.
I no longer touch the programmed thermostat. The high today is going to be around 44 so we are burning. If the HP comes on, so be it. It lets me know to open up the air a bit on the 7am fire and let it roll.I was considering daytime highs as my decision maker but these cat stoves burn for 24 hours and so I moved to nighttime lows as being the criteria. I light the princess in the evening after it gets dark when temps are forecast in the 30s (I like to be stealth about my burning) and so the initial pulse of heat happens after the heat of the day and sets me up for a long cruise trailing off in the heat of the next day.
I don't leave the heat pump on or turn it down when I burn, I shut it off. Otherwise it keeps blowing. Of course, it's still powered up and ready but is "off". With wifi, I can monitor temperature and turn it on from work if a surprise cold front comes in.
This could save me a lot of wood. Also could save a lot of catalyst life.
Funny how we all become more complacent as we age😝. Heat pumps are amazing.I no longer touch the programmed thermostat. The high today is going to be around 44 so we are burning. If the HP comes on, so be it. It lets me know to open up the air a bit on the 7am fire and let it roll.
When I am heating with wood the system rarely comes on. If it does it's only for 5 - 10 minutes. Otherwise it's off. When it comes on it reminds me it's time to open up the air a bit or put some more wood on.
10k for a gas furnace? Wow, I didn't know they were that expensive.My 2021 $10,000 NG Furnace almost NEVER comes on. The thermostat reads 71F so long as I toss 3 NIELS into the stoves every 10 or so hours.
