Ive been burning my new Boxer for about a month now so I'm no expert. But Ive found the firebox size to be a bit of a challenge, the length and width aren't an issue despite being trapezoid shaped. But the overall height is restrictive. My splits are fairly large in comparison to yours. I can only manage to get 3-4 splits across the bottom (north/south) and not have room on top for anything other than odd small pieces especially under the cat, and maybe one in front like your photo shows.
By looking at the photo of your dial, its just about the spot on my stove where I can hear the flap shut. Meaning it can't be turned down any lower even tho the dial can still be rotated counter clockwise. If you listen as you turn the dial down, you can hear the flap close. Take a pencil and make a mark there for reference.
What I found with my stove is if I turn it down all the way, the window will get cruded up to the point its almost impossible to see thru. Also in the slow burning mode not a lot of heat is produced, just a longer burn time. I added photos of my dial with the top pencil mark where I normally hear the flap close and the lower mark is where is seems to produce the most efficient burn in terms of heat and time. But this does need to be adjusted during the burn. I've yet to see where I can simply turn dial to a given spot and walk away without having highs and lows during a burn cycle. I also added photos of my current coal bed with cat thermometer and flu temp. My cat normally stays in the active range all of the time even with very few coals as pictured.
View attachment 306272 View attachment 306273 View attachment 306274 View attachment 306275
