Go there! See Santa and he'll sign a book for you. And go to the Notty Shop in Salcha. And stovies will love The Woodway in Fairbanks.North Pole = brrr
You make it sound so glamorous 🥶 Try living it for 30 years and see how ya like it 🤨Go there! See Santa and he'll sign a book for you. And go to the Notty Shop in Salcha. And stovies will love The Woodway in Fairbanks.
March is the world famous ice carvings competition! You think you've see ice carvings? I went it was -44F and the experience was sooo cooool.
Google Fairbanks Ice Carvings and click on images....
See you there in March 2023!
I try to visit 3-4 times a year. Only once in the winter. Glamorous? I think Homer is more glamorous, but there is no place like home, wherever that is.You make it sound so glamorous 🥶 Try living it for 30 years and see how ya like it 🤨
Yeah it's a nice place to visit but I wouldn't want to live there... Oh wait 🤦🏻♂️I try to visit 3-4 times a year. Only once in the winter. Glamorous? I think Homer is more glamorous, but there is no place like home, wherever that is.
Nope. But run it at 90% so thermostat has so latitude for adjustment as wood collapses. But I've run my King at 100% many times.Is there anything wrong with running my Princess thermostat on high for full loads to bring up the base temperature in the house and then turn it down closer to 4? Utilizing proper bypass operation of closing as soon as you load it if on the active zone and flue temps are also good.
First, we need to acknowledge the single greatest variability in stove performance results from the fuel we use. The fuel we burn can vary load to load, not the least of which is season to season. Someone called our offices a little bit ago and I listened-in on the call.I know this has been discussed many times but I'm feeling too lazy to go back and search. What are some characteristics of a cat that is showing signs of being less efficient (aka, starting to fail)? Visible smoke through the burn, with cat thermo in active zone? Decrease in cat active burn times? Less consistent burn times?
I believe the manual states to make a fire w/ t -stat at full setting, once the cat become active close the by-pass and wait for 20-30min at full setting then turn the t-stat down to the halfway point and wait, if the cat falls out of active range, then its no good.I know this has been discussed many times but I'm feeling too lazy to go back and search. What are some characteristics of a cat that is showing signs of being less efficient (aka, starting to fail)? Visible smoke through the burn, with cat thermo in active zone? Decrease in cat active burn times? Less consistent burn times?
In my experience with very cold weather you can run the A30 at WOT for weeks on end, never mind just on the weekends, with only slightly shorter than average combustor life expectancy. I am still saving money, after combustor replacements, compared to my previous non-cat EPA cert stove. A lot of money. Thousands over the 8.5 seasons this stove has been in service. Honestly more than enough to have paid for the stove. 3 loads per day at WOT x 30 days, roughly 90 loads at WOT annually times 8 years, no problem.I've been running one of my Ashfords at 100% a lot more than usual this year, since I work from home now, and don't mind feeding the stove on a less-predictable or more frequent occasion. But speaking to longevity, I've spent 7 years running it at 100% any time very cold weather coincided with a weekend (meaning maybe a dozen loads over 4 weekends per year), and have seen no ill-effects.
You might try running your burns left to right (or R-L) instead of front to back. Wrangle your coals over to one side, put your hardwood on the opposite side, then fill the box with softwood. You will get a bit of front to back burn anyway because of the airwash, but you might find better coals. When running 2 burns per day I like to have coals on the door latch side of the firebox in the morning for faster light off when I am trying to get out the door.Interesting (to me) observation. Last night I loaded the box with pitch pine and two splits of red oak on the bottom layer. On the one hand I have the needless concern that the pine won't last long enough (as I said, no need for that, see below), on the other hand I like to have some coals for reloading, and oak does give me those.
Well, at this point (13 hrs in), I have about 35ish pct of the wood left to burn (the low was 31 F only), BUT the two splits that are almost completely gone are the oak splits...
Probably just because of some airflow and previous coal distribution on the floor, but my coal-plan is not working out today....
You called it.I will probably have a cold stove in the next few days (thanks to ADEC).
My deck fans get turned on around Oct.1, and turned off sometime in April, but they're always kept running at a very low setting. The difference in convective coefficient between no fan and one running very low is huge, there's no need to run them on higher settings, in most circumstances. Furthermore, one of my stoves is located in my office, where there are some high power computers, one of which regularly sounds like an airplane preparing for takeoff. So between that and a few humidifiers scattered around the house all winter, I don't even hear them running.I will say @Ashful probably runs his deck fans more than I do as he has more intense need for the convective ability of the A30 than I do; because of the stone exterior walls of his home. I probably run my A30 24/7 at WOT (wide open throttle) with the convection deck fans on high only 2-3 weeks per year. Maybe 4 weeks sometimes. With children home the deck fans are not discernable parts of background noise for me. As an empty nester I have become very aware of noise as an escalating influence for my mentation and delay running the fans as long as possible in colder weather.
Good to hear on the longevity of the stove, but how's this work with your work schedule? You work 3x 12 hour days, meaning maybe 13 - 14 hours(?) away from the home, but you said you can rip full loads in 4 hours at WOT. This is what always kept me from doing it, even though my house sometimes calls for it. I just kept plugging away at 12-hour reload cycles, when I was working away from home, dicated by my availability for being there to reload. The central heating had to pick up any slack.In my experience with very cold weather you can run the A30 at WOT for weeks on end, never mind just on the weekends, with only slightly shorter than average combustor life expectancy. I am still saving money, after combustor replacements, compared to my previous non-cat EPA cert stove. A lot of money. Thousands over the 8.5 seasons this stove has been in service. Honestly more than enough to have paid for the stove. 3 loads per day at WOT x 30 days, roughly 90 loads at WOT annually times 8 years, no problem.
I would say if you aren't running your stove through a full load or three at wide open throttle annually, you might have bought too big of a stove.
I guess I was half joking. Given every install is different in all the varieties of insulation envelope and the variability of airleaks blah blah, running the stove low moderate through the bulk of the heating season with a few hot and fast at each end should keep up with the stove hygiene items I was thinking of. I don't happen to live in a climate like that though.I disagree though you may have been joking, hard to tell through the interwebs. Obviously, these BKs are optimized for low/medium output where emissions are lowest and efficiency is highest.
Wouldn't you be happier Poindexter running a 2x sized ashford at a slower rate?
I run some short and hot loads near the warm ends of the shoulder seasons just to clean or keep clean the firebox as much as possible since corrosion seems to be a realistic concern. 95% of the time I'm at a pretty low output keeping the house warm for our very long burn season and I am very happy with my stove sizing choice.
