I would think that a batch of dry skinny splits might overwhelm the cat with smoke from all outgassing rapidly at once.
But it's not. Just split your current dry wood down and see if it makes a difference.
in the beginning maybe. But I'm talking about burn times. As long as the cat is active when I walk away (the pre-requisite in any experiment, because otherwise things just go south), the Tstat should cut the air to regulate the heat output. Of course doing anything that suffocates the cat won't work, but that's not what I'm asking about.I would think that a batch of dry skinny splits might overwhelm the cat with smoke from all outgassing rapidly at once.
3-4" splits or 6-8" splits...
If one expects the cat to reach end-of-life within a year or so, that probably makes sense. My cat likely has less than 1000h on it by now, so for me it makes little sense to buy a replacement cat now.
I should add, emissions reductions of PM 2.5 takes place in chemical conversion at 550F or thermally at 1176 F. So, "low" can be very different between combustion designs...not always FBV that fixes need for low, longer burn times. It's like having a Camry with a 50 gallon fuel tank. It won't get you further than the 30 gallon Camry if you drive 100 mph!If you place a thermocouple in the firebox, connected to a digital display and manually lower the air input (not always possible depending upon minimum air setting used in testing for certification) to compensate for the unmetered nature of burning cord wood, you can impact burn times. I've experimented with this in cooperation with another manufacturer and adjustment intervals were nearly every 2 minutes. At times you'll need to increase air to sustain combustion....Great question by the way.
Great question.. short and simple - alien technology.how does BK claim a 30 hour burn when no-one else claims even half that?" to incude "and how come nobody else gets a 30 hour burn time when they have stats at just as low a burn rate and just as big a firebox?
if is go low and slow, that means no flames in the fire box, very dirty solid black glass, maybe occasional embers flaring or glowing I will get 20-24 hrs a load, this serves me well when temps are in the lower 30's at night and the day recovers to mid 40's or warmer.
As is gets colder out I adjust my t-stat air control, this makes the fire burn hotter, the hotter the fire more flames ect.. my max burn in the depths of winter (temps low teens / upper single digits at night and teens during the day) running the blower will average 10-12hrs per full load, more or less the same (maybe slightly better burns then other 3cu ft stoves on the market, but pretty close to others) this results in constant flames in the firebox, a hot cat to the burn clean, stove top temp of 600 ball park and a warm house.
Thanks KennyP; I get it now. The extreme slow is a smouldering, dirty burn. How well does the cat deal with that?
tech is a good answer too.
Still dont see why stove brand X with a cat doesnt claim a similar burn time. Or do they just not consider that slow a burn?
Ashful stopped by recently but has been MIA for a long time.Hello everyone, just getting caught up on this year's thread. On page 6 of 20 lol. Anyway, it's finally in the mid 30s here in NE PA and the sound of the heat pump running is getting me itchy to light up the Princess. Its been match ready since early April. Supposed to have a few nights in the 20s this week. Anyway I'll start with 2 questions.
1 - on my indoor pipe, I've been using single wall since I put in the princess 3 years ago. I have 2 straight sections and 2 - 45ish adjustable elbows with 18 feet of blanket insulated double wall above the T. I was going to replace the inside pipe put of precaution this year, although it's in good shape with no rust. Is it worth it performance wise to try and get a double wall stainless to fit? Draft wise the stove runs good wit a low burn around 145-2 o'clock on the Stat on hardwood.
2 - maybe this was covered, but is Ashford still on the forum? I used to enjoy is scientific approach to stuff and his writings. If he isnt around anymore, I hope all is well.
Good to hear he's all good, that was my main concern.Ashful stopped by recently but has been MIA for a long time.
Yep, you must put in a new gasket every time you pull out the cat. Mine crumbled to dust when I pulled the cat out in order to clean it… I’ll never do that again: pull the cat out only if you want to replace it with a new one.Am I correct in remembering that the cat cannot be removed without replacing the gasket?
VC stoves have the cat and tstat combo but I bet the down draft design probably requires a little more air to burn properly thus reducing burn times. Also the new Jotul F500 has a tstat for it’s secondary air only. You would think more non cat stove manufactures would do this for the secondary air systems to keep them a bit more controllable. I believe PE is the only one?No, it's the combi.of cat and Tstat. Wood fires always fluctuate. Set it at your lowest speed (longest burn), things settle, move, and suddenly your speed goes up. That needs to be damped.down to reach the longest burn. Without a Tstat cutting the air, you can't do that, and your total burn time decreases.
When things get hotter, draft increases, and it gets even hotter. Tstats control that. Also preventing runaways, overfiring.
So the best comparison would be to compare to another stove with a Tstat (not that common) AND a cat. I don't know of one, but I vaguely remember having read that at least one other exists. Someone more knowledgeable will confirm or tell me I'm full of it .
