BKVP
Or...just maybe...sip on a vintage bourbon and not think about the flame path..we already worked that out for you.
I’m partial to Single Malt Scotch. Though I can’t afford the good stuff. But at $25/bottle Finlaggen is surprisingly decent.Or...just maybe...sip on a vintage bourbon and not think about the flame path..we already worked that out for you.
Middleton Very Rare 35 Year!I’m partial to Single Malt Scotch. Though I can’t afford the good stuff. But at $25/bottle Finlaggen is surprisingly decent.
It will be ready next fall for sure!I burned a 8 of the Idaho logs last night because my remaining wood isn’t quite ready yet. They burned fine and they were still fairly solid this am considering the setting I had them on. I did notice they didn’t put out quite as much heat when I cranked it up for reload which I thought was odd. Be glad when my wood on the drying rack is ready. It’s close, 19 on one and 21 on a bigger. Splits are pretty big
You don't have to use the fan if it is not necessary. 90 to 95%of my burns are without the fans. Some not even have them.I have no doubt the answer to my question is somewhere on this forum but...
Is it safe to burn my Ashford 25 insert with the fan off for extended time? It heats the house easily and i would like to set it as low as I can and turn off the fan.
Thanks.
No fans on my Chinook, either. Works fine without, although I do have the ceiling fan on for heat distribution.You don't have to use the fan if it is not necessary. 90 to 95%of my burns are without the fans. Some not even have them.
You're good to go.I have no doubt the answer to my question is somewhere on this forum but...
Thanks.
(3) huge 8" diameter un-split oak leads
Those logs were cut 3 years ago and put into the wood shed as is 2 years w/ bark, I got this idea way back when @BKVP posted that he threw in this huge square round before leaving town. The rounds had that look to them that they should weigh a certain weight but when you pick them up they feel lighter, also had some good check marks on the ends.Nice! Can I ask how long this has been seasoned (covered, after bucking)? I've been hesitant not splitting oak... Did you debark?
ok. Thanks.
I had some oak rounds stacked (off the ground, tarped) b/c my split-wood storage was full (I needed to work on that).
This was wood I got in April 2020 or so. Rounds of 12-18" dia. I just split all I had laying like that, and I noticed that there were already bugs (whitish larvae, possibly the Roundheaded borer larvae) under the bark, digging 1/4-1/2" tunnels. I found similar in standing dead pine that had progressed farther in. I was concerned that this would accelerate rot/punking of the wood. Split wood seems to be too dry for these bugs. But you having it 3 years w/o major issues is good news.
Thanks for posting your stove top temps. Most don’t seem to do that, they just set the stove to run at the room temps they want. Which BK model are you running and how many square feet of home are you heating?Last night dropped down to 14 with a stiff wind from the NW (right off the swamp by me) loaded the princess around 8pm (kicking myself in the butt for not taking a pic) but I had (3) huge 8" diameter un-split oak leads that I jammed into the fire box on a hot bed of coals, 13 hrs later the stove is still chugging along, stove top is running about 475 deg f, lots of big lumps of tree coal in the rear of the fire box and most importantly, a warm house that didnt drop below 68deg. Not bad in my book.
Have mine top center under cat probe as it shouldn't get as much air under that area on this stove. Tells me same thing, I don't know if I've ever really burnt this thing with active flames much beyond reloading in the year and a half I've had itlets me know when I'm cruising along better when I have a no flame fire box and the cat is doing the majority of the work
