2020-21 Blaze King Performance Thread (Everything BK)
Pics! Without pics, it didn’t happen.
I went to a house fire last night, ended up getting pretty wet and had to deal with frozen gear and a soaked sweatshirt underneath, got home and loaded my princess just like yours, took a shower and then turned the t-stat off of my bake setting, went to bed, low temp was 20f with a refreshing 20mph gusty wind so I had the blower on medium.
When I woke up this morning my upstairs living room is sitting at 70, and only 2/3 of the load was burnt through so I turned the t-stat back up to burn more down so I can do a full re-load before I leave for work later this morning. Having this BK dialed in like I do, I dont know how others deal with 6-8hr loads that are found in other stoves when it gets cold out.
They just reload a bunch of times, wake up colder, and enjoy the temperature swings. But the glass stays clean and no cats to buy! Long burn times are so much better so long as you’ve properly selected a stove/home that stays warm at those lower settings.
When it’s cold, and higher outputs are desired, the reload times can be as short as 3 hours on my noncat. Up to 8 hours when trying for long burns and match free relights on a 200+ degree stove. My last noncat was a soapstone and could make it 9 or so if the wood was ashy enough to mask the coals.
If I had some sort of cheap heat from a furnace then i might be convinced to try one of those good looking noncats again when this BK needs a break. Until then I’ve been spoiled by once per day reloads, constant warmth, and no fiddling with the air control.
Reactions: Indianawood
I'm looking to change stoves. The stove I have now is pretty good but I'm not burning it much because of the lower burn times. It gets about 6-7 hours of burn and needs somewhat constant babying. It is a jotul F500 so it can crank out the heat but by house is kind of chopped up and doesn't do well with transferring the heat and it doesn't really like to run low and slow. I'm looking to get an Ashford 30 to replace it. I'm only burning standing dead pine and I want a realistic opinion on what I can expect for burn times on low, medium and high. Any help would be greatly appreciated.
First thing I would do is take a handful of your "standing dead Pine" and do a fresh split on it for a immediate moisture check on the freshly exposed inner face. Be sure the pieces selected for eventual testing are indoors long enough to be up to room temp prior to splitting/testing. Do you have a moisture meter?
I had one and then I returned it to amazon because it was defective. New on is coming. I'll have a better idea on that in a week or so.
Reactions: moresnow
Climate can affect burn time as it changes the draft. That said, with a full load of small splits of alder and cedar I was getting solid 15 hour burns without stalling the cat. Bigger splits and replacing the cedar with birch and maple and I’m expecting 20+ hours from a load on low.
On high I don’t think burn times will be any longer than a tube stove for the same amount and type of wood.
Not having any experience with a tube stove I hesitate to say what you would get for burn time, but probably similar to a tube stove on low but with still active secondary burning.
Reactions: hardcore
I have an Ashford 30 and also mostly burn standing dead pine (beetle killed lodgepole). Temps this winter are mild, with overnight lows and daytime highs ranging from 15-35 Fahrenheit +/-. I have no problem getting 24 hour burns on a full load of 8-10 splits at these temperatures. The fastest I've ever burned through a load was about 9 hours on med-high when the temps were -20F and below, but I've never had to continuously run on high.
But it will depend more on how your house is set up as far as size and insulation, etc. My home is only 1400 square feet with fair insulation.
Edit: also be aware the Ashfords are very finicky about chimney, so verify your size and height before moving ahead.
Reactions: Highbeam
Holy heck, I haven’t been here in forever. Glad to see the BK madness still going ;)
Nothing else on the market comes close! Your signature says you have a noncat PE. This is the BK thread. Are you going to upgrade?
  • Haha
Thanks for the input. What don't they like for chimney setups?
Just follow the owners manual. 15’ minimum all vertical 6” at sea level. Add length for bends and altitude as specified.
15’ is really tall for a single story home. I only have 12’ but that met requirements for my 2012 princess.
Reactions: hardcore
Sold the BKK with the house in 2015.
To be honest I was scrolling through my contacts today and saw @rdust number still there and thought I should check in.
At least if one is (gasp) not going to run a BK, the Super 27 is a very fine option IMO...
My 27 is in a vacation home. I don’t burn full time anymore and miss it all winter.
It is capable of some ridiculously long, reasonably comfortable burns for such a small firebox, or I can crank it up and load it every 6-7 hour if I need the heat.
That little dog is a heat whore lol [Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK)[Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK)
Yesterday the wife said she was feeling cold so I turned the stove up and about 4pm I noticed it was starting to coal. I should have left it alone but I’ve been wondering what to do with these huge chunks that didn’t want to split sooo... I threw one in and left it turned up pretty high. Lol, that was a bad idea. I had the door open for a while to cool the house down. It did burn down to where I could stick a couple pieces in for the night. House stayed hot even though I turned the stove way down
Reactions: Diabel
Get cutting!
Lol, no kidding! I’ve got about 1 cord ready to burn now. Better than I expected really. Got an unlimited supply of fir snags but have to stagger the two drying racks which are 8’ . Not super dry but seems to burn pretty good after a couple weeks in the stove room. Be glad to be more prepared next year for sure
This is one of my piles I need to whittle on. That’s my elk hunting buddy in the yellow coat.
  • [Hearth.com] 2020-21 Blaze King Performance Thread (Everything BK)
Reactions: Nealm66
Madness you helped start!! Glad to see you’re still around!
Is your sister(think that’s who it was) still using the BKK you rebuilt?
So, question. When I start up the stove, and the bypass is still open, I can see the flames drawing to the open bypass.
However, when I close the bypass because the cat reaches active stage (and I don't immediately turn down the air), I often can't see flames being pulled towards the cat even though that is the only way out.
Flames in the back of the box seem to go up towards the bypass. Not "pulling" there (at all), but clearly not pulling to the cat either.
Cat is nicely hot, burn times are long (14-16 hrs on 3 o'clock, near 24 on low), I can hear and feel the bypass locking in place with the second resistance that I feel when I move the handle, and I have visually (not with a dollar bill) checked the bypass seems properly closed. Flue temps are 150 ish (single wall, magnetic, 4" after the end of a 90 deg bend that is 2 ft above the stove, with the first two ft and the elbow being double wall - all this will be replaced with proper double walls, 45s, and a shorter horizontal run soon).
Bottomline, I think it runs well, and only me staring into the box leads me to this question.
Do you see the same or should I see flames pulling to the cat when the air is open enough?
I see much the same thing, I believe with the resistance of going through the cat the air flow wouldn't be nearly as strong as just an opening. Just my theory and observation
That was my theory too, but consistent observations to confirm this are nice.
I do see the flames in the front of the firebox "blowing away" from the door due to the incoming air though (with a Tstat far open)... And what comes in has to get out in the same rate, and given that the cross sectional area of the cat is similar to that of the air wash slit, I was wondering...
