Whatstove are you running? Generally yes, lowering primary air will raise cat temps. Have you checked your gaskets? With your primary closed I don’t think you should be seeing any primary fire. How tall is your flue?Doesn't seem to matter where the air is set. Even all the way closed I get those temps, always have flames in the box no matter what. I actually think I get higher temps the more I close the air once it's going well, almost seems as though running the stove hotter burns more smoke before it gets to the catalyst.
Sent from my Nexus 5X using Tapatalk
