Hi, im still having some problems with my Intrepid II. No matter what i do it seems to be more smoke than it is supposed to be leaving the chimney. I usually let it reach 230C on the stovetop and then engage the shutter. with primary air fully open, then I close it slowly and sometimes i can get the fire to almost die down so there are secondaries in the firebox and a lot of smoke passing through the cat but there is still quite a lot of smoke from the chimney.
If the wood is burning a lot when i close the shutter a lot of the times i cannot get it down to only secondaries even with the primary all the way down, so i can seen flames going and also reaching the entrance to the cat. And even then there is smoke coming out of the chimney, not more or less than in the other scenario.
I had a chimney sweep (which is mandatory in sweden each year) and he said that i had almost no soot at all, he wanted to lower the amount of mandatory sweeps to every third year instead. This indicates that at least there is not much creosote building up i guess but i cannot understand why i see as much smoke as i do?
And for reference this litte stove is inserted in a danica cabinett which makes it very hard to adjust things on the back like the chain for the primary air shutter for example. I can feel that the shutter for the air is almost closed when the setting is closed on a cold stove, not sure how much it closes when the stove is hot though since its to hot to be there fiddling with the hand wihout seeing what you are doing
I guess the problem with not beiing able to shut down the flames could be a gasket issue, but the smoke issue? I have very good draft i can add, with the door fully open and using small wood from the beginning it roars when starting. I have no cat temp sensor (to hard to install in this cabinett since it would demand almost a full rebuild) and also no sensor on the stove pipe. the pipe goes up for about a meter and then vertically in to the wall and up again if that has any impact on the issues? From what i understand this would only reduce draft which i cannot see is the problem :/
Well this got quite long but any input and ideas is appreciated, new cat maybe?
