RandyBoBandy
Somewhat of what you are experiencing is common with people new to epa stoves. The common complaint is “I can’t get this stove to burn, it doesn’t heat like my old smoke dragon, this stove sucks, etc”. It is usually related to wood being to wet for modern stoves to burn correctly and efficiently. Another thing that could be an issue is your draft. How tall is your new chimney? This measurement is from stove top to rain cap. I haven’t looked at the intrepid manual but the encores and defiants require a minimum 16’ at around sea level to 1000 ft. If your primary air flapper is not moving with the primary air control than this is definitely a problem. Is there an Allen head with a cable attached to this flapper? With the stove cold put the air control in the closed position and adjust the flapper so it is touching the frame ( all the closed basically). Tighten the Allen head and check for movement with the control.Hi All - posted this in another thread but thought this would get better responses in this thread.
I recently (as in 2 weeks ago) installed a VC Intrepid Flexburn w/o the cat converter (model 2215). I have started a few small fires over last weekend and let them burn out per the O&M manual. Also - new chimney installed.
Last night I tried to start a fire and it seems like it is starved for oxygen even with the heat adjustment lever being at high. When I would open the front doors - the fire would perk up. The smoke would draft very well up the chimney.
When I would close the front doors - it seems like the fire would peter out regardless of what setting I had the burner adjustment at. I poked around the rear end of the stove and discovered an air flap just inside where the combustion air goes into the stove. Regardless of where I set the heat control lever - the flapper didnt move. It seems to me like this could be the issue. Should this flapper be linked somehow to the heat control lever?
I am getting minimal / zero support from the company I purchased it from and am quite frustrated with their lack of customer service so it seems like I am going to have to go at this alone.
Any help would be appreciated. Thanks!
![[Hearth.com] 2018/19 VC Owners Thread [Hearth.com] 2018/19 VC Owners Thread](https://www.hearth.com/talk/data/attachments/241/241560-9b5b0e76ca65a3c647a6a6ce3efe3967.jpg?hash=VZPA0fONvn)
