Ashful
Glad you got that figured out, Kenny. I’d sure be happy if you kept that Princess, and stayed with us, now that you’ve got it running nice. Only you can decide what works for you.Well, I have the NC30 on order, but I also have the princess up and running. I installed the new cat on Thursday, also an additional pipe damper approx. 3ft from the top of the stove ( I have double wall telescoping pipe, needed to be above where the two pipes collapse on each other) The stove is running really well, great output, 14-15 hr burns, it has been in the upper teens at night with some wind and the stove has preformed excellent.
I'm at a cross roads here, I think I'm still going to take delivery of the NC30, drop it off at my friends welding shop to do the convection deck and then wait and see what the princess does.
As far as cat issues, self inflicted I think, I think my over draft caused to much heat and fried the cat causing its short 1.5 season life span. This cat btw was a ceramic, so I had the original metal, then ceramic and back to metal. I'm not impressed with the whole needing parts thing, but maybe I stumbled onto something as far as really controlling my draft, I running the top damper closed 100% of the time, this brings my draft down to .010 - .012, then I close the collar damper 1/2 and the flames get nice and soft, new cat (should be over active) but with this setup my cat probe only goes to 1 o'clock position so perhaps I have things in check, the old ceramic cat when brand new without dampers shot up to 5-6pm at the same settings, I specifically remember that.
Since you’re already mod’ing the NC30, maybe it’s worth running it the rest of this year, and hanging onto the Princess a year while you make the final decision. I’d hate to see you sell it, and then have remorse.
I have pegged the cat thermometer many times on my short chimney, too. So that alone would be a tough way to determine if you have overdraft. The issues I see when draft is too strong are:When you guys talk about your overdraft issues, is pegging the cat a solid indicator of that? Or, is it possible to have overdraft issues with a cat only 2/3 of the way into the active zone (2 o.c. Position)? All those poor oblivious stove owners out there.
1. Hotter chimney.
2. White-hot raging fire if I leave the stove on wide-open throttle for a long time.
3. A clogged cat after a day or two running on high.
Yes, you can install a manometer permanently. Look in last year’s BK performance threads (probably February 2018) for my install. I went with a 0.25”WC Magnehelic, a section of high-temp rubber hose, and then a stainless tube into the chimney penetration. I could drive the stove without this, but it does help, and makes it less intimidating for my wife (she knows to just turn the key damper until Magnehelic reads .05”WC on high burn).
