10f right now and furnace comes on about once an hour to 75mins for about 5 mins
I agree they can throw enough heat but there would be a coaling problem I think
to produce the btu's necessary to keep the building a that temp, I assume, not knowing
your heat load requirement, but going by mine I have to run the 2 stoves, f600 burning
8-10hr loads and the ashford contributing during the coaling stages for the f600,
and even then I need the furnace to help out when we are single digits to sub zero, as we will be for the next
10 days/nights except for our midweek snowstorm coming.
if I ran the ashford as hard as you did I probably could keep as warm but would have frozen pipes after a
few days.
Unless it doesn't get above freezing for highs, I can usually hold room temp burning down coals. Stove top will pop back up to 350-375 for a few hours if I open up the air on 'em, and the sides of the stove will heat up nicely too.doing back to back high burns on oak, I'd have a stove full of coals in a few loads.
It can have its benefit sometimes. A mix is perfect.It almost sounds like softwood is better for this frigid weather.
When you have crappy semi wet wood (20-22%MC) in a coal bed upon reload they won’t ignite... well after 45 min they will.
If it’s really 20-22% it’s not wet, if it’s taking 45 minutes to light it’s much much wetter than low 20’s. Low 20’s on a meter is ideal. I have oak seasoned for 4-5 years and it’s 16-18% on the inside of a fresh split at room temp.
Well the bark is mossy and has some fungi on it. Upon splitting the MC is 22. —- pre split it’s 19%. But it’s split when it’s been cold, which could affect the MC/reader. The bark is keeping the layer beneath moist I believe. It was standing dead for 2 years when I bought it. They cut to order, but it’s all standing dead.
My tarping job hasn’t been the best as wind rips it off occasionally causing varying surface moisture increase.
Bring enough in for a couple days worth and stack in near the stove. The surface moisture will dry up fast, if the internal m/c is in the 20’s it will burn just fine.
Do you get water boiling out of the ends?
Yes, if you need exercise, and want to burn twice the calories for the same BTU benefit, softwood is the way to go. But you also need to be available to load twice as frequently.
I don't think twice is a right statement. I will give you under same conditions, maybe, two loads more per week on average. My experience BTW.Yes, if you need exercise, and want to burn twice the calories for the same BTU benefit, softwood is the way to go. But you also need to be available to load twice as frequently.
Or, more likely, many of those BTUs blew out the top of the stack. The Ashfull 30 doesn't put BTU into the room at a high rate/hr. according to that 'spec sheet.' 28K isn't much.Ashful, 5 hours! Wow. With damper keeping draft in spec? That must have liberated those Btus to your space at a rate much higher than the epa spec sheet indicates is possible.
Right. Red Maple or Black Cherry are around 20K BTU/cord, Red Oak is 24K. When you get up into Dogwood, Hickory and BL at 27-28K the difference is more apparent.Since softwood is easier to lift it won’t take twice the calories. I thought softwood was only like 25% less energy dense than your oak.
Yeah, driving up those valleys near you, I started seeing a lot of Pine and Western Crottenwood..I don't burn hardwood as you cause it is not my main supply plus is not what is available right away
