Can't pass that up. White Oak is the King of all Firewoods.I’d rather not mess with anything that big if I can keep from it but I have a similar sized white oak that uprooted and fell into one of the fields I need to get started on.
Soft Maple, yes, about like Sass. But Hard (Sugar) Maple seems about like Red Oak to me, maybe a little better.Maple gets half credit as a hardwood, along with sassafras
Yeah, chit goes wrong fast, when handling 6300 lb. logs with 2000 lb. tractors. I debated skidding that one whole, but decided to cut it to two segments of 7.5' (2600 lb.), and the butt as a final 3' length. Even then they can tip the tractor fast, if they roll on uneven ground.Those logs make your JD look like a toy.
This one had been sitting on the ground at church awhile. A few people ahead of me had said they wanted it, but no one was getting to it fast. There's another much bigger ash, which must be > 40" diameter x 40 feet of straight trunk, which I was going to grab. Unfortunately, one of the other guys came in and cut the entire length of it to rounds, which makes it completely useless to me. No way I'm moving rounds, anymore.I feel for you. I’d rather not mess with anything that big if I can keep from it but I have a similar sized white oak that uprooted and fell into one of the fields I need to get started on.
I had an oak like that a couple years ago. It made me want a hydraulic log lift on my splitter.
Cats purring right along...View attachment 238205
No sir. I am running a proprietary combustor. Long before the public is offered something, we beta test. It is a ceramic substrate but has special application of metals.Is that the 10 year old, full time burning supercat?
Yes... also take a look at the flame shield, as the cat dies off you will start to notice a lot more fly ash on the shieldStill on my original cat but I guess I need a replacement now,
last night I reloaded after 16hrs and got the stove up to temp
then charred the load as usual but this time when I dial back the
stat the cat prob went down right along with it.
I gave it a bath in sept, '17 after it had degraded some, but this is different,
has anyone have their cat just give up like that.
So you’re just raking everything forward, and placing one good split E-W behind it to burn them down? I stirred my coals up, raked them forward and then ran a load of jack pine on them, however i still have lots left buried deep. Think I might try your approach, only instead of a NEILS i’ll use a Pj split.It worked great! It reduced coals about twice as effectively as just taking forward.
thanks kenny I will take a look when things cool down a little.Yes... also take a look at the flame shield, as the cat dies off you will start to notice a lot more fly ash on the shield
There are a few beta testers out there running it for us.....Hmmmmm. Certainly somebody else independent should be testing one of those elsewhere as verification...….Incase you run out of volunteers!
Geez, half the work is done. I'd roll my splitter right up beside those & toss splits right off it into my trailer.![]()
Not behind, but on top of. I built a coal rake with a 3' handle. I posted a picture years ago. I rake all the way down to the brick. Build a huge pile in front of door. Then load a NIELS East.West and it burn sooooo hot it cooks the coals down to ash!So you’re just raking everything forward, and placing one good split E-W behind it to burn them down? I stirred my coals up, raked them forward and then ran a load of jack pine on them, however i still have lots left buried deep. Think I might try your approach, only instead of a NEILS i’ll use a Pj split.
Where do I sign up to be a beta tester ??There are a few beta testers out there running it for us.....
X2! Since I missed out on the socks and all.... I did get 2nd place for my pup in front of the stove contest a couple years back thoughWhere do I sign up to be a beta tester ??
I'll put you on designated reserve list.Where do I sign up to be a beta tester ??
Ditto...designated reserve list.X2! Since I missed out on the socks and all.... I did get 2nd place for my pup in front of the stove contest a couple years back though![]()
