One man’s “glaze in the lower corners” is another man’s black glass. I burn low and slow almost all the time with pitchy evergreens and have never not been able to see the fire. Just some glaze in the lower corners!
I will if i don’t want the furnace to kick on, but only when its below about -30*C. Otherwise i can get through the night no problem with enough heat.Do people really wake up in the night to reload there stoves?
We're gearing up for just this kind of cold snap. Arctic air moving in tonight overnight and persisting through to next week. And I plug my truck in every night during the winter!If it hit minus 30 more than once, deg C or F, I’d be moving. Holy crap, that’s too cold.
When you need to put an electric blanket over your car’s engine in winter, that’s a bad neighborhood. [emoji3]
Unless it experiences mechanical failure (fracturing to the point where it falls apart), or is poisoned by burning chemicals, they usually don’t just “go bad”. They more generally fade, so slowly that the owner really has a tough time making that judgement call on when it’s time for replacement.After a few futile searches I figure I'll just ask. How do you tell if a cat is bad?
I’m not sure the age of your combustor, but I’ve settled into replacing every 3 years. I could stretch them longer, if I needed to, but the performance gains by switching out after 3 years are so substantial that I don’t have any desire to run one longer than that. I’m burning 3 - 6 cords per year per stove.I have a Princess, manufactured in 2006. I bought it used in 2016 and I'm in my 3rd burning season.
The amount of volatiles coming off of the wood to keep that combustor active varies throughout the burn, peaking in the first few hours, and then waning over the course of the next several hours. The ability of a combustor to remain active during that waning period is affected by the age of the combustor. Also, those pushing for extremely low burn rates (our fellow BK burners) may starve the cat for fuel, with a new cat having a much better ability to stay active under these conditions.Second question is burn time. I've read that burn times decrease when a cat is failing. Is this because the air has to be increased or does a cat really effect burn times?
Thanks for the info. I'll probably ride this one out for this season and get a new one for next year. I usually run it st the 2 setting (3:00) any lower and the cat does stall. The #2 setting seems to keep my 1800 sqft ranch at 74 in the living room and high 60s in the far bedrooms.Unless it experiences mechanical failure (fracturing to the point where it falls apart), or is poisoned by burning chemicals, they usually don’t just “go bad”. They more generally fade, so slowly that the owner really has a tough time making that judgement call on when it’s time for replacement.
Generally, the first thing I notice is that it’s falling out of active region sooner than it had previously. The second thing you’ll notice is they’re a little slower to light off, but this is always the lesser indicator for me. Remember, a combustor can remain active when the fuel feed rate is lower than would normally support secondary combustion, once it has successfully lit off.
Others note the amount of smoke out their chimney, but I’ve never really paid much attention to that, myself.
One thing you’ll see as a common recurring theme here, is how many posters replace their combustor and then say, “I can‘t believe how much better the new one is, I’ll never wait that long to swap, ever again.”
A failing cat does not directly decrease burn times, but an effort to keep it active (and thus producing acceptable heat) may have their owners increasing the burn rate, which does result in shorter burn times. A secondary burn stove, maybe especially the catalytic variety, exhibit a quantum drop in efficiency when the secondary system falls out of combustion.
True. To me:
Glaze = translucent brown
Black glass = opaque
Well my wood is not optimal. On cold starts it takes a while to get going and on reloads on coals it takes forever. It’s around 20-21% MC but it’s the best I have. NIELS do not exist around me either. The only other option is to try to source better firewood when buying it or use eco logs which aren’t cheap to run daily. I’m going to really clean the glass and see if I can keep the wood in the back.
My only problem is due to my small split sizes, the Ashford 25 eats wood pretty quickly. If I set it on low, it doesn’t produce any noticeable warm heat. So normally I have to put it on medium and the fan on medium. This gets me about 4-5 hours of useable heat.
20% mc and 4 hour burns on medium? There is something else going on there, that's not even close to right.
Well what’s considered total burn time? Like cold stove to cold stove or cold stove to coals “useable heat” ?
Any times I quote don't have 'cold stove' on either side of 'em, I burn 24x7. Loading wood onto coals in a hot stove,
The definition is highly subjective. A lot of people here use 'cat active', or >500°F in the firebox. There is no actual standard as to what people or vendors mean by burn time, though.
You're lucky you had faucets to drip! (Begin Monty Python skit here...) We used a galvanized pail to smash the ice in the well to get a bucket of water to wash with!
I’m doing something wrong or my wood is terrible. My cat only stays active if the box is stuffed and blazing. Once it burns down it falls out of active zone quickly.
When you turn it to low how low are we talking here?
Lopi Rockport
Blaze King Ashford 25
The blowers cause a false reading on the cat probe. Turn them off for 10 minutes before checking.
You have something else going on too. Having to turn a bk up to medium to get heat, with 20% mc wood?
Either your wood is way wetter or some other problem exists.
Let some wood warm up to room temp, then split it, and test the mc on the freshly split face.
Well, upon loading and once it gets going I close the bypass. Then when it’s in the active zone, to get it to heat up the living room, I let it rip for 15-20 min or so than turn it down to about 3:00... 2:00 on the dial the valve goes “clink” so I back it off.
Now I don’t usually run it on low due to there isn’t much heat on low. So my wood, oak, must be still too wet. Maybe I’ll buy two bundles of kiln dried wood... pack it completely full, once it’s going set it on low with fan on low to measure burn time.
After a few futile searches I figure I'll just ask. How do you tell if a cat is bad? I have a Princess, manufactured in 2006. I bought it used in 2016 and I'm in my 3rd burning season. Usually light it up in Oct and burn constant through March. Burn red and white fir and lodgepole and maybe use 1/2 cord month. When it gets 20 deg and below I usually get a minimum of 12-14 hour burn. Cat seems to light off, glow properly and stays active through the burn. I have done the vinegar clean twice. The cat does have a crack in the center but seems stable and is not crumbling. Just curious as I've put around 11k hours and I'm not sure how much the PO used it (it was like new).
Second question is burn time. I've read that burn times decrease when a cat is failing. Is this because the air has to be increased or does a cat really effect burn times? I'm trying to understand how if a cat is not plugged how a failure can reduce burn times. Sorry if this has been covered before. So far I'm very happy with the stove. Saves me a fortune in propane.
Excellent point. I was speaking of stoves in general, as most of my failing cat experience was with Jotuls, and not remembering this is the BK thread.Ah but this happens automatically, the thermostat does this without asking.
3. I report my cat staying active for very long stretches, burning oak, but what that really means is the exhaust coming off the back of the combustor is over 500F. For all we know, the cat may NOT be active as in eating fresh fuel, but the exhaust temp of the primary burn is just hot enough to keep the air flowing thru the combustor that hot. Who knows?
