Can you let us know how you start a fire and what your process is with engaging the cat and thermostat management?
Also, have you disconnected the OAK and tried it?
Tx for your reply. Yes, how do I start a fire?
At this point, Dec 2018, will load a mix of Ponderosa or lodgepole pine and pinon pine. Pinon is excellent wood. Beautifully sweet smelling, high BTU, low ash, great wood. My stores measure from 5% to 11% moisture content. Will create a box of pinon with towards the door, open. Will build up the box with the Ponderosa or lodgepole splits. I always leave a couple inches along the rear of the firebox to allow for easy circulation. I then complete the build by placing some pinon splits along the sides of the box. Will leave at least 6-8" of space in the front of the firebox. For circulation, and to prevent any splits from falling onto the glass.
Will place a 1/2 block of composite firestarter in the middle of the 'box', and pad it with dry chips. Pinon preferrable. As one can hold a fire source on the pinon wood and it will catch and go. It is a wonderful wood type for starting, and sustaining a fire.
Bypass plate open. Air flow open 100%. Light the composite 1/2 block and go. Keep the door cracked until a fire begins to take off. Often times I close the door because this works so well, the wood is so wonderfully available, I do not need to keep the door cracked. Draft is always A+... so don't need the door cracked. So is a 50-50 thing.
Once the fire takes off, it takes 5-7 minutes from the start to get a pretty good involvement. I close the door it it isn't already closed and dial back the air flow about 25%. And let the wood char for say 10-15 minutes. The cat temps come up during this time. So approx 20+ minutes from the start, the cat temps are ready to engage. I will close the damper and dial the air flow back to about 50%. It takes less than 5 minutes more for the temps to fully engage the cat. It is easily glowing red.
Because of the systemic smoke smell, I can only dial the the air flow back to just before it "clicks". I have read others do same. I go through the same ritual each time. My problem is, because I have not been able to figure out the smoke smell emission into the room problem, I cannot dial the air flow back to a simple sustained flow. The moment one experiences the "click" on the air flow dial, smoke smell is released into the room. It takes less than 5 seconds. Therefore, I cannot run the stove in a sustained more because I have to have a reasonable fire flame to keep the smoke smell at a minimum.
But I cannot run in this mode either because while the smoke smell is always being released into the house, even tho I can minimize the smell, if I keep the cat engaged, eventually the wood burns down and when it reaches say 80% depleted, the fire flame diminishes and then the stove emits the highest level of smoke emission. Meaning, I can't run the stove for more than 5-6 hours because I have to keep a flame going, and when the flames stop, I get hammered. I cannot for instance sleep, because I have to tend to the fire and either add more wood (which means I am tearing through a lot of wood unfortunately), or, I have to forget the the cat and run the stove and keep the bypass open constantly, to prevent the smoke smell from overwhelming.
I am for all intents having to run the stove like a smoke dragon, bypass open, while I try and figure out this smoke smell emission problem.
And yes, I have run with and without the OAK engaged. I am well familiar with the air pressures of this 2 story house. So I have to manage pathways of air in the house to spirit the smoke smell up and out second story windows. More to the point, when I run the stove without the OAK connected, with air coming from the room, with windows open, it runs the same as when the OAK is connected. No, I have not tested with a Manometer but have been asked to run this test. Never needed to as the draft and air flow across 3 stoves has been quite successful for 25 years. Will run this test yes... so long answer is OAK or no OAK, stove hums along dandy fine. I initially had some puffing but this was due to a spate of heavy creosote buildup very fast when burning silver maple. It created a real mess. I swept the flue and stove. The pipes are pristine. I can open the door and compose a symphony and not have an iota of back puffing.
Way too many words... but my typing fingers ran away with detail. A shorter answer would be I can from start to engaging the cat... be 20+ minutes tops. I just cannot keep the cat engaged due to smoke smell emission.
