darktower007
I still don’t understand this statement, bholler. I see two issues with it:
1. There will always be days, in every house that is ever built, when you need just a “little” heat. Yes, I guess you could build small fires throughout the day, to pump and glide. But what about those who are away from the house long stretches, or who want to sleep through the night? It would be quite an exercise to pump the house up to just the right temperature on a small hot load in the morning, to arrive at your desired temperature when you return from work at the end of the day.
2. The ability to run low just means you can go bigger on the fuel tank, for any required heat load. The greater turn down can mean a much bigger stove for a given heat requirement.
I’m not saying there is no disadvantage to the cat stove, I’m just saying that I don’t understand how you can claim there’s people heating with wood stoves that can’t make some use of a wider range of output.
I’m also not saying non-cats can’t work, obviously many people are doing it. I’d just rather cruise low and slow, than play pump and glide games, particularly in a house with more rapid heat loss.
Living in the south this is why I went with a BK.. I don’t need a flame thrower. Just a nice fire for a few hours and then low warm output.
Now my buddy in north Minnesota? He needs a torch to keep his teeth from chattering.
It’s all based on where you live, your current lifestyle, and budget. My budget was $1100 for everything at first....I guess I can thank this thread for spending 4 times that amount! Lol
I look mid-winter but have only been brushing once a year. But some might be more concerned with creo than I am..I get about 1.5 qts. when I brush. Most is at the top so I don't worry about it much.
