The EPA tests may not exactly reflect real-world operation but the range of outputs is based on four different burn rates from low to high. The fuel loads are structured so the numbers should be good for general comparison, considering the number of different stoves tested..they can't
all be fluke or outlier tests I wouldn't think.
Yes, the Woodstock AS appears to go lower as well as higher, except for the BK 30.2 but for some reason the numbers for the 30.2 don't display correctly in the chart..peak output
can't be 2711 so I don't know if we can trust that low number of 1553.
Agreed, jury is still out on how the cats in the hybrids will hold up but the PH has been in the field several years and I haven't seen anything yet to indicate that their life will be shortened (I haven't followed it closely though.) Anyway, I don't try to go real long before I replace a cat..usually swap when they start to drop off noticeably in performance after several years.
Even a straight cat stove will let some particulates by if you open up the air too far, as has been reported by owners of all different brands.
I have no backup heat fuel use to calculate my heat loss on. All I can say is that down to about upper 40s day/upper 30s night I can easily get by on one load at night of mid-output wood (River Birch, Black Cherry) in my little Keystone, and the room temp doesn't swing more than two or three degrees. I don't see a need to burn lower than the 8500 it is rated at.
OK, keep us posted. Maybe you'll be converted and we can start our own little Woodstock cult.
The numbers are the result of tests at EPA-accredited labs, the manufacturers don't come up with the numbers. The tests have to be run within specified parameters.
I don't troll, unless you call poking a little fun a couple of "elves" trolling.
Go ahead, poke some fun at me, I don't mind.
I don't want to argue with you, as a troll would, I just offer an alternative to the stuff you sometimes throw out there, like "The rest of the stove world is way behind with developing a stove offering such a wide range of outputs." Well, I disagree.
That said, I at the same time commend you and Ashful for being frank in discussing some of the stuff that's less than stellar about your stoves. I hope I do the same when talking about my stoves.
See, now this is the kind of good-natured ribbing I'm talkin' about!
Yeah, I wanna be a "pain in your butt" to keep you from falling asleep and your stove taking off on you...oh yeah, that's right, you have the thermostat to save you.
I'm also not a big fan of using asterisks instead of
italics.
Hahahaha, good one!
Haven't moved the bed into position yet, but I
did break out the down comforter.
Well, if I was as muscly as you, I could lift those huge buckets of ashes. But I'm not that manly so I have to just pull the ash pan every few days and hope I don't strain myself.
I
was out your way several weeks back but didn't have time to get in touch about stopping by to check out your stoves. Wasn't cold enough anyway.
View attachment 233356 View attachment 233357 View attachment 233358 View attachment 233359
Well, it wasn't that early but when I watched the 6:00 PM local news/weather a while ago, and saw that the freezing rain was starting, I knew I wasn't going anywhere, and broke out the liquid heat.
Thanks for taking the heat off me!
Anything I've measured with a micrometer has been what they claimed, like 1/4" on the Buck 91..
Bah, "unlike."
You live in NM, "don't sweat it."
