Really? You dont think.i checked that.Sounds like under seasoned wood. Or poor draft.
I think there’s a difference between a flash fire in the connector pipe than a flue fire. It’s a very short lived event that does not spread to the chimney. I wouldn’t call that a flue fire.I understand that. But you said you didnt think it was a flue fire then went on to say that it lit off the buildup that was in there.
Hearing this kinda scary for a newbie like me!
Have you ever read the csia white paper on flue fires? That is what is used by fire companies insurance companies etc. And according to that what you described is a flue fire.I think there’s a difference between a flash fire in the connector pipe than a flue fire. It’s a very short lived event that does not spread to the chimney. I wouldn’t call that a flue fire.
Ok...Have you ever read the csia white paper on flue fires? That is what is used by fire companies insurance companies etc. And according to that what you described is a flue fire.
I am barely running 13ft of pipe on mine and have no issues with light off and kindling with the little propane torch.Because its a pita to start
I’m just basing the description on real life experience. It’s alarming when it happens, there’s no doubt, it’s easily snuffed by shutting the bypass and not a big deal unless your chimney has been neglected.Have you ever read the csia white paper on flue fires? That is what is used by fire companies insurance companies etc. And according to that what you described is a flue fire.
OkI am barely running 13ft of pipe on mine and have no issues with light off and kindling with the little propane torch.
I can tell you this! I burn 75% less in the BK VS the old boiler! lol
Yes i agree not a big deal at all. I said that from the start. But if there was creosote burning in the venting system it was a chimney fireI’m just basing the description on real life experience. It’s alarming when it happens, there’s no doubt, it’s easily snuffed by shutting the bypass and not a big deal unless your chimney has been neglected.
That i beleive without a doubt lolI can tell you this! I burn 75% less in the BK VS the old boiler! lol
My wife was none to happy initially when I told her my plans to install a indoor stove....as she had never experienced a indoor stove and was very apprehensive about it...but has grown to understand it and how to run it and loves it now and understands it saves me a lot of work as well!That i beleive without a doubt lol
I just had a quick chimney fire because, IMO, I kept the door cracked too long during warmup. Good thing I was there watching my flue temperature suddenly start whipping up. I slammed everything shut which on the bk actually means just that little air hole in the intake flapper. The young fire snuffed and the probe meter only climbed to about 1100 before stopping.
Whoa!
I pulled the probe meter out and the probe is shiney copper. No roaring or rumbling but crackling in the pipe.
Everything is normal now.
I never crack my door, load the stove and close the door.
In the beginning I experienced what you have on a few occasions. One was the day after sweeping the pipe and chimney. When the stove is in bypass flames can shoot right up the pipe and overheat it rapidly. I always try to load the stove with a split dead center in the stove so flames won’t be able to shoot right up the flue. If I see flames going right up and the cat probe is still not active I flip the bypass lever closed and say F it. Cats are cheap, I’m not having the pipe light off and start a chimney fire.
@bholler, energy consumption is proportional to indoor temp minus outdoor temp, integrated over time. If your house is spending more hours per day at 72F with the BK, then you’re moving a lot more heat to the outdoors than if it cycles down to a lower temperature during off-hours, and wood consumption will reflect this.
I suspect you’re also burning at times that you might not, if you were running another stove. Yesterday was in the 50’s all day here, peaking around 57F, and I had mine running. If I waited for temps to drop below 40F, I’d burn half as much. If that threshold was 30F, I’d burn a quarter of what I burn now.
Follow the manual instruction of lighting a fire when cold and on reload procedures. That will give you a good starting point. Bypass needs to be closed when the cat reading is going into active zone.Hi, I got a BK Ashford 30 and I LOVE it! What a huge difference in the house from my old pellet stove. This is my first wood stove and first Catalytic stove (which I was and am apprehensive about). It has been a learning curve this off season. I have a few questions because I am so worried about doing something to wreck the cat. I may be misinformed, hence I'm here to learn...
So far, I've been mainly burning Pine, which burns quick and not as hot, but it does produce a lot of creosote when the stove is set on not all the way to low. I've been able to fill the stove and leave it to burn for 8 hours on that setting without needing to refill. Which was nice for overnight. This week, I've started to use a bit more Birch, which burns cleaner and definitely hotter, so I've not been filling the stove but only putting in a 3-4 pieces of wood in and burning it on medium, and even then my house is HOT, too hot, and I've had to refill it 3-4 times a day. My worry is that if I set it on low, I will get too much creosote (like with the Pine) and I worry about that as it's not good for the stove or the chimney but I would get longer burn time. I don't want to eventually start a chimney fire, especially if I'm not home and the dogs are. But if I set it on medium, I can only fill it a little at a time and then I'm opening the stove 3-4 times in a 24 hour period, which is not good for the cat.
As far as the cat is concerned I've been told conflicting information. The instruction book said to wait until the cat thermometer is indicating the cat is still active but barely before reloading, but the sales guy told me to wait to refill only when the cat is inactive. This last week, since I've had to refill the stove more often, I've been worried out of my mind about the cat ... sometimes I can't wait for the cat to be inactive or even on very low active before refilling (I either have to go back to work or sleep) ... so can I open it to refill even if the cat is in the mid range of active (and of course by-pass the cat before opening) or is that NEVER to be done? This week, I've just been leaving it and coming back to a cool house or waking up to a cold house.
Also, sometimes, I've forgotten to close the by-pass for 1/2 hour before I remember and close it when the stove is burning, because I'm afraid of closing it too quickly after I've opened it to reload. How long should I wait to close it if I reloaded it when the cat was still in the barely active stage?
Sorry for all the questions, but I just don't want to wreck a brand new stove ... thank you in advance.
It will be interesting to see what cycle burns the most wood for you, all day low heat or evening warm up fires.
