AlbergSteve
You'll have to experiment with turning the stove down a bit at a time without letting the cat go inactive. If the cat's active, it's burning off creosote.and even then my house is HOT, too hot, and I've had to refill it 3-4 times a day. My worry is that if I set it on low, I will get too much creosote (like with the Pine) and I worry about that as it's not good for the stove or the chimney but I would get longer burn time.
If the bypass is open, it won't hurt the cat.ut if I set it on medium, I can only fill it a little at a time and then I'm opening the stove 3-4 times in a 24 hour period, which is not good for the cat.
If you wait for the cat to go inactive, you may not have coals left to do a hot start. Every time you do a cold start, that's a dirty start, putting creosote where you don't want it - up the chimney and in the atmosphere.As far as the cat is concerned I've been told conflicting information. The instruction book said to wait until the cat thermometer is indicating the cat is still active but barely before reloading, but the sales guy told me to wait to refill only when the cat is inactive.
Load the stove on your schedule. I'm burning cedar right now so I'm not getting long burns ie. not 25 hours, but 12-14. Last night I loaded before going to bed, about 10pm and at 9am this I loaded again, even though there was a quarter load left from last night. We never come home to a cold house!so can I open it to refill even if the cat is in the mid range of active (and of course by-pass the cat before opening) or is that NEVER to be done? This week, I've just been leaving it and coming back to a cool house or waking up to a cold house.
Also, sometimes, I've forgotten to close the by-pass for 1/2 hour before I remember and close it when the stove is burning, because I'm afraid of closing it too quickly after I've opened it to reload. How long should I wait to close it if I reloaded it when the cat was still in the barely active stage?
Doesn't hurt to get a good char on the wood before closing the bypass if it's inactive, otherwise close it after loading. If I have a full load, 20-30 minutes is typical.
There's a bit of a learning curve with these stoves, especially as temperatures change and the type of wood used changes - took us a couple of months. Once you've got it sorted out, it'll be just as easy as setting the furnace thermostat!
Somebody with years of BK experience please go over to BH's place and check out his burning routine! Sumpin ain't makin sense. At all? How can you burn more in a stove you should only need to load every 12 to 20 hours?
