Agreed, hard to get uniform results in these tests when, as you've said, the load can shift or something else happens during the tests.
Recently, in response to
@Ashful's bogus claim that the BKs had "unmatched range of output," I posted an image of EPA test results for each of the BK and Woodstock models which show the BKs have ranges of roughly 20 K BTU/hr. or less, compared to Woodstock ranges which are much higher, pushing 30 K in some cases. ALL of these tests can't be flukes. I saw that Ashful recently repeated this false claim. But he's chosen to slap an "ignore" on me, so he can't respond and instead chooses to stick his head in the sand.
I can't easily tranfer that image right now, navigating the site on this dumb smartphone while I wait for a SSD to arrive for my desktop.
But the results are shown here if you scroll down and click the hyperlink "List of EPA Certified Wood Stoves."
(broken link removed to https://www.epa.gov/compliance/list-epa-certified-wood-stoves)
Good question. Also, how do transfer rates change in the real world, when the innards of these stoves are full of creosote flakes?
No, I'm pretty much stuck with a rear-vent stove if I want to enjoy the look of my masonry fireplace without a connector pipe in front of it. That's why I read and post in this thread..I'd like to hear some theories/answers from those that actually run the stoves. For example, what is the purpose of the additional shielding inside the BK fireboxes? I think it may be to keep heat up inside the stove, to allow the cat to stay active at lower burn rates. And is that also the purpose of the pot-bellied, cone shape of the original King and Princess models? And why do they want you to burn the stoves on high for 30 minutes after reloading? I can get a load of wood burning well before 30 minutes, with air settings well below wide open. Is it to burn off the creosote that has built up between the interior shields and the walls of the stove on a previous low burn? Is that the reason for the thin 1/8" walls on the stoves, to get the walls hotter and burn off creo quicker? And what happens to the burnt creo flakes that fall off the walls..do they build up between the shields and the walls, further impeding the release of heat into the room? I'm looking for some in-depth analysis of the design features of these stoves.
And what's the response to my questions? Cricket noises, and the ongoing flood of posts claiming "superior alien technology" or "Ooooo, I just got a 24-hr. burn from a load of Pine twigs and dryer lint." Where's the in-depth analysis of how these stoves work, by the supposed "stove nerds" here at hearth.com? Might be a stretch, calling this a "performance thread."
