Holy turkeys! When it's 70* F here I'm in a tank top and gitch, starfished on the lawn trying not to overheat! What are you doing running your stove when it's this hot out!I burn my BKs on days where the high temp might peak in the mid 70’s, and get away with loading every 36 hours with constant active cat in the shoulder seasons.
Pictures.....or it never happened....lolHoly turkeys! When it's 70* F here I'm in a tank top and gitch, starfished on the lawn trying not to overheat! What are you doing running your stove when it's this hot out!
Your shoulder season is my red hot summer!
Be careful of what you ask for!Pictures.....or it never happened....lol
A few things to note, here.Holy turkeys! When it's 70* F here I'm in a tank top and gitch, starfished on the lawn trying not to overheat! What are you doing running your stove when it's this hot out!
1. I said "where the high temp might peak in the mid 70’s", as in a day with 50F low and 75F high. With the BK's, one load carries me 24+ hours, at these temps. So, I just load and let them roll right thru.
2. Most of my house was built in the mid-1700's, and has 20" thick stone walls. They hold somewhere between ground temp (53F in winter) and average daily outside air temp. On the aforementioned 50/75F spring day, my interior wall temps might be in the high 50F's all day long. Not exactly winter, but not tank top temperature, either.
If it goes in the low 40s at night I'm probably burning. But then the highs might just barely hit 60. Not a lot of 30 degree temp swings like in the arid west and southwest.43/71 here, burning a half load.
If you ever visited this house, you would be very underwhelmed. Not a hint of haunting, here.3. The Stony Tomb Of The Dwarf-King has its own weather patterns, unrelated to the mundane weather of the mortal realm. Those who have trodden here and survived... were not of the clan Jo-tul.
Livin' large he is, with two sources of heat.We're hanging around 50º, no burning today or tonight.
What do they do with the cranes, clean up all the debris, flotsam and jetsam from stuff that exploded due to extreme low temps?yes, spring is here...The cranes are coming. Takes about 6 weeks for them to get here from NM, maybe ten weeks.
Three. It was sunny today. That warmed the house up nicely.Livin' large he is, with two sources of heat.![]()
Big group of cranes heading north this morning. Hummmm.
Can winter be over?
Can winter be over?
