kennyp2339
Hey guys I know the info I'm looking for is on one of these pages but could anyone tell the high temp grease they use on the t-stat ? mine is starting to feel a little chunky lately.
I had my installing stove company re-gasket the door one month in from new. Yes, I know it stinks but they did it for free. Yours might too but wait until after the flue is increased as it will be better but likely still smell. Handy re-gasket tip: place paper between the door and the stove so it is not inadvertently glued shut from any squishout. Open the door once to verify the gasket did not roll out, close it and don't open it for 24 hours. No peeking or the flames of Hades might prevail.
Temporary fix: place ~17" strips of Rutland thin flat window glass gasket in both of the lower corners. Place it a little past the dirt marks on the glass. It is self sticking and can be removed. Stick it to the gasket, not the stove. This helped me a lot until I fixed the short flue problem. Available at Ace and other hardware stores.
NAPAHey guys I know the info I'm looking for is on one of these pages but could anyone tell the high temp grease they use on the t-stat ? mine is starting to feel a little chunky lately.
Is it now fixed 100% for your stove? Can you lower the thermostat a lot more than before (noon..?) before the smell come back when outdoor temp is above freezing point?
Copper anti-seize. I get it at any auto parts store.
Before I could not lower it below 4:30. That setting would usually be way too hot for 960 sqft. In the winter I shrink my 1,591 sqft house down by closing doors. Now 3:00 is about as low as I can put it as later in the burn the cat will go inactive. You can only run a stove so slowly so It is kept at 3:30 or hotter as needed. The thermostat positions I use will be different from yours. I would say the smoke smell thing is 95% fixed. By the time it is at the smoke smell point, the stove is not needed anyway. Heating a small space like mine is a big challenge for any wood stove. The Ashford stove is a wood stove dream come true in the area of controllability and burn time. You might say the smoke smell problem is managed and not a problem. For my situation any smoke smell definitely comes from the lower corners of the loading door and nowhere else.
That's normal, mine stays higher than that for hrs before start dropping. Normal cruise in low is about 2 o'clock. I always do a hot burn after reload and it goes pass the scale. BKVP said that as long is into the active zone, is all what matters.Anyone else have their cat run this high?
If that were true then you could open the door and smoke wouldn’t pour out. The pipe is under low pressure but the firebox isn’t always.
Well, what stove and where in IN?Thanks for the info, I'm new to this and loving it.....
That looks like a problem. I also don't see an indentation on the vertical part of the gasket...can you easily pull paper out there? Yeah, it should come from the factory better than that but let's not lose sight of the fact that this is a BK.when i really started to look at the gasket, i noticed that there's not a lot on the inside seam at the top corner (also the spot where i think the smell is coming from) - does this hunk of gasket look right? this stove is only 2 weeks old - i would think the gasket should come good to go?
no, the whole door holds a paper just fine, and yet i'm getting some smoke smell whenever i try to dial the t-stat down. at first i thought it was coming from up around the cat probe, but then also noticed it along the door on the hinge side.That looks like a problem. I also don't see an indentation on the vertical part of the gasket...can you easily pull paper out there? Yeah, it should come from the factory better than that but let's not lose sight of the fact that this is a BK.![]()
Ya, the paper does tear when i pull it, but i agree the gasket looks a bit off. this is my first wood stove, so i don't have much to compare to. any suggestions for my next move?You do realize that the paper should not just be held by the door but also be clamped tightly to where you risk tearing the paper by trying to pull it out, right?
What a crappy factory gasket job. The gasket should be continuous and centered on the knife edge of the stove. For several reasons other than stink you want the door seal to be very good and I thought that the factory would also consider this a higher priority.
i'm not gonna lie, between the door gasket not looking the best, and also having to adjust the bypass plate tension, i'm starting to get a bit bummed out with the stove. frustrated that i have to deal with this stuff on a brand new stove?Ya, the paper does tear when i pull it, but i agree the gasket looks a bit off. this is my first wood stove, so i don't have much to compare to. any suggestions for my next move?
Yeah I would be bummed too.i'm not gonna lie, between the door gasket not looking the best, and also having to adjust the bypass plate tension, i'm starting to get a bit bummed out with the stove. frustrated that i have to deal with this stuff on a brand new stove?
so, the company that installed the stove for me isn't a dealer, just WETT certified installers. they bought the stove and installed it for me, and i think the stove might have come from a dealer in Winnipeg. I'm not sure what to do exactly - so far the installers have billed me for even calling them, and i'm pretty sure they're not going to do anything for free. not sure what kind of recourse i have here - i see in the warranty that gaskets are excluded from day 1. this is disappointing.Yeah I would be bummed too.
We have been burning a new Sirocco 20.1 for a month now and it's been flawless and as hoped. 20 hr burns, yadda yadda yadda. We do have a great draft I think with our high ceiling, and our gaskets are all tight etc. My .02 is your draft may be borderline. Seems to be a recurring theme with the "smoke smell" discussions here and makes sense.
That gasket too though, not perfect by any stretch... where are you in Ontario? Did you get it from a dealer? I would be looking to them for support. Our dealer/installer was awesome, knew everything about the stove and comparisons to other models etc. Was a big help in getting us going and dialed in.
I know service is hit-or-miss these days but I wonder if you tried the dealer?
I hear ya. Ok if I were you I'd just call up Blaze King myself then. I think you did about the bypass, but maybe not about this new gasket problem yet?so, the company that installed the stove for me isn't a dealer, just WETT certified installers. they bought the stove and installed it for me, and i think the stove might have come from a dealer in Winnipeg. I'm not sure what to do exactly - so far the installers have billed me for even calling them, and i'm pretty sure they're not going to do anything for free. not sure what kind of recourse i have here - i see in the warranty that gaskets are excluded from day 1. this is disappointing.
