This weekend I finished up my BK temp monitor, some may remember I had a flue and stove top
monitor/controller on my Regency, It was 2 separate boxes.
For the BK I wanted to have flue, cat and stove top monitor, all in one box, so that is what I did.
The top is flue, middle is cat and bottom is stove top.
The flue probe is inserted in the double wall pipe about 18" above the stove collar.
The cat probe replaces the standard cat thermo and the stove top TC is bonded to the steel top
with furnace cement under the cast iron jacket.
Each controller has a high temp alarm, the flue is set for 875
the cat for 360
(the active mark on the original thermo)
the stove top controller will turn the blower on at 675
It is nice to have a audible signal to remind you to close the bypass, as soon as the cat is up to temp.
Makes it much less likely to forget and leave it open all night (someone did this on another thread).
This stove is so much better than the Regency it replaced, the amount of heat it puts out is amazing.
The living room temp is usually somewhere between 70
80
. I have a couple of small fans on the floor
blowing towards the stove to circulate the heat, that pretty much keeps the whole house warm.
The long and consistent burn time keeps the house warm all day and night. I my not need run the oil burner at all
![[Hearth.com] 2017-18 Blaze King Performance Thread PART 2 (Everything BK) [Hearth.com] 2017-18 Blaze King Performance Thread PART 2 (Everything BK)](https://www.hearth.com/talk/data/attachments/217/217054-24ed2ebd61af40cdc926a1612bccba46.jpg?hash=3hiqjAdNoD)
