Thanks! That was my concern. Draw. We'll I could build a chase up through the knee wall, but being that I am going to be remodeling in the next year...I will go with it. It is snowing hard right now, but I would rather dial it in when the weather is colder anyway. Hopefully I can get 12 hours out of a little warmer burn for now. The house is old and drafty anyway. I've got to drop a few firs, and a large spruce in my yard. That may help draft a little more. I will post a pic of the outside.I did the dual-45 thing, and no issues here, but I have 29 feet of pipe on that chimney. I have another chimney that's closer to your 16 feet, but it's all straight.
On that shorter chimney, I can't burn quite as low as I can on the longer one, until the weather turns real cold. That means no nice low-and-slow fires on 55F days, on that pipe. On the longer pipe, I burn on the lowest setting on days when outside temps hit 65F.
So, my answer is that you can definitely put a 90 degree bend on a 16 foot pipe, but then you're severely limiting the low range of the stove in warmer weather. Given that this low-and-slow capability for burning long on less-cold days is precisely why most are willing to spend a few extra bucks on a BK, you're sort of negating some part of your investment, by doing this.
I'd go with dual-45's, and then you'll just have to find where your stove is happy running on this pipe. In cold weather, it will not be a very big issue, as draft will be much stronger. But on warmer days, you may experience some stalling at very low settings.
edit: Another option is always extending your chimney a little taller, either continuing up with that unfinished chimney core block I see thru the window, or by transitioning to class-A above the masonry.
The old NG earth stove is still in the house. I am not removing it until the blaze king goes in. That's four inch galvy you see now. Am I understanding your question correctly? Unfortunately, I'm not very bright. I recently bought this place,So what are we looking at there for flue pipe? Is it B-vent, galvanized, stainless, spray painted?
Thanks jetsam. I may shoot some elevations tomorrow with my lazer. That way I can get a little better measurement. Not that one inch will matter. I would rather do it right the first time.I had a little less height than BK asks for on mine when it was first installed. I added a couple feet of flue, and it's made a huge difference in warm weather. I had some smoke spillage sometimes when reloading in warm weather, which was greatly reduced, and I feel like I can start up faster and burn a little lower now. (I don't understand why better draft matters when you're barely using any air, but I feel like adding the height helped my low burn somehow.)
Quick... how do you spell "stimulated"?Unfortunately, I'm not very bright... lazer.
I'm ordering a stove this week. It'll be a Blaze King. I was measuring out some clearances. My wife wants the smaller stove since the room isn't that big where the stove is going and doesn't want to lose any more floor area than she has too. My stove will be mounted at a 45 across a corner.
It looks like Ashford 20/30 will actually take up about the same space in the room (at min clearances due to the corner clearance requirement being 6" on the Ashford 20 and 4" on the 30. This means the 30 can actually sit about 1.5 inches deeper into a corner, which negates it's additional depth, and the width is negated by the reduced corner clearance.
Am I doing my math wrong?
I think the corner clearance will be the limiting factor in a corner install. For the hearth pad it'll be 18"front min, and 8" behind and sides (wondering if this affects corner clearance).
Ashford 20 26.5" wide x 27.125 deep x 6" corner clearance
Ashford 30 29.5" wide x 29.25 deep x 4" corner clearance
this is VERY hard for me to say but....we installed a h-h-h-heat pump this summer![]()
Woops, my fault, I thought that the photo was the BK with a b-vent hooked to it. Now that I look closer the glass is way too big. Get the BK in soon, snow is here!
Ok. The dealer I bought the BK from called and flexed their incompetence. That is the only stove I really want, but it looks like I'm back in the market for a stove that has honest, hardworking support staff. Unfortunately the other close dealer for blaze king is too far away. It is part my fault though. The last couple times that I went through that dealer they hacked the propane inserts. Being a building contractor, I just won't refer them to customers, or use them for any new construction. The last two kids they sent out were too young to shave, and when I got into the attic to seal the chase up, the pipe wasn't even connected right. I wonder if Blaze King knows?
