kennyp2339
East coaster's don't use ash pans.. we're dangerous folks and roll our coals to do clean outs!I'll be joining you my man!
We call that a blower exhaust, which comes standard. You can buy a "convection deck but it takes up way to much of the top surface. This is a change we introduced in earlier this year.My Sirocco convection deck starts at the back of the stove top and comes ahead towards the front until approximately the middle of my pipe. Very small and not at all a hindrance to cooking area. Cooking would appear to only require a higher thermostat setting than your normal low setting. Never tried it but expect it could be accomplished.
Heck that ain't nothing! During winter with freezing rain and slick roads, 90% of drivers in the US slow down, in Eastern Oregon we say "hold my beer dude watch this!"East coaster's don't use ash pans.. we're dangerous folks and roll our coals to do clean outs!
You must be talking about Woodyisgoody, because I have him on ignore, too.Threads look kind of surreal when two people are posting back and forth to each other, but you have one of them on ignore.
"Who's he TALKING to?"![]()
(Also a lot of "Throw me a beer, I'm still in this ditch!")You must be talking about Woodyisgoody, because I have him on ignore, too. I thought we all did?
Dunno, the message board doesn't tell you that a post is hidden, it just hops to the next one.
Good system, really, because everyone can curate their own list of people they don't want to hear from.
If you have moderators doing that, not everyone agrees with their choices, and banned people just sign right back up under a new name anyway.
I don't know, I keep even the most irritating people off of the ignore list. Sometimes those folks are just in a funk. Sometimes I am just in a funk. Then later you really appreciate their input. I can't believe that Webby3650 didn't punt me long ago! It's kind of like your brother that you fight with but he's your brother and you'll get over it in time, that is, unless he drinks the last beer.
I saw the weather maps shifting that ridge more east and creating a trough for you in the west, I actually thought of you and begreen, I said they're gona be liting up their stoves real soon.Burned fire #1 for the season yesterday and will do another tonight. We're officially in the fall shoulder season!
During the off season I did a little metalwork on my bypass retainers and now I find that my bypass is too tight. Going to have to take off the flue and loosen the bypass tension bolt a bit. Probably lube the ramp while I'm in there.
How did you determine that the by-pass was to tight? I'm just curious.
The offsets make a tremendous difference in draft..
Also, It appears this is the first season for the stove.
I can see it working well, but was wondering if the plug would seat down easily without vacuuming the grove out? The pan does look very clean. I'm just used to shoveling. But if a guy spends that kind of extra dough, he might as well use it.
I use the ash plug on my 30.0.
Less airborne crud in the house.
Run the tool around the perimeter of the hole like webby described, works great.
And i can do it while the stove is hot to keep the ashbed in the floor of the stove in the sweet zone without having to shut down. Just push the coals to the back, ise the tool to pull the plug, get your hockey stick on, replace the plug, spread the remaining ashes, spread the coals, reload, empty the drawer.
I wasnt a believer until i realized i could do it hot, and without making a mess.
Ignore is for the thin skinned IMO LOL.Threads look kind of surreal when two people are posting back and forth to each other, but you have one of them on ignore.
Well, 90's and Tee's are never good and should be avoided.Seems an offset like that would be quite negligible in comparison to a flue with Two 90's like hooking to a masonry chimney.
![[Hearth.com] 2017-18 Blaze King Performance Thread (Everything BK) [Hearth.com] 2017-18 Blaze King Performance Thread (Everything BK)](https://www.hearth.com/talk/data/attachments/200/200376-58455f3283bff82cecdbb4b0dc7dde5b.jpg?hash=pcoB3jHXk5)
First burn in the Chinook 30! Worked like a champ:
A pleasant surprise was the amount of secondary burn and good show of flames on med-low setting. I wasn't expecting it to be this good based on some advice seen here that catalytics weren't as good for flame viewing vs. tube stoves. I could also turn it down all the way and the flames would extinguish but cat temps stayed 2/3 - 3/4 into active zone even as the wood was burning down to not much more than ashes.
I guess I had to see it to believe how long it could "burn" cleanly with no visible flames (unless you count the ones dancing about the combustor).
I think, most of the owner of cat stoves just try to reach the temp the cat need to engage the cat and charr the wood some more and dial it down to whatever is your settings. That can make the stove not to get into those secondaries beautiful flames. but if you burn hot for awhile and dial to low in steps, yeah, you get some nice secondaries. When is not like tube stove and last as tubes, still beautiful and enjoyable. Maybe i am wrong, but i think most of the time we don't burn hot enough to make it happen.
. Family looking at me like, REALLY.I am jealous, I got some early mornings dropping into middle 50s last week, but the house was staying comfortable around 69-70. can't find an excuse to burn. Family looking at me like, REALLY.
Okay, have my CAT on order. Hope it gets here soon, while we may have a bit of warm weather left. Give me a chance to install it and clean the stove out before winter hits hard.They need gaskets! Ignore the misinformed. If you purchase from firecatcombustors.com, they come with the gasket.
The weather changed like someone flipped a switch. I did the same and turned on the heat pump, but it won't be long now before we're burning.I saw the weather maps shifting that ridge more east and creating a trough for you in the west, I actually thought of you and begreen, I said they're gona be liting up their stoves real soon.
I was all ready for fall too! Well almost, I still don't have my BK hooked up. No stoves at all for me at the moment.I feel your pain! It's forecasted to be almost 90 F here this weekend!
