Fans finally showed up yesterday. I was sent the large stove fans mistakenly to begin with. It has been a interesting wait. My burn time, heat output etc. had been somewhat disappointing when outside temps were below 20 F roughly. I did not install the fans yesterday as I was busy elsewhere.
I woke up at 2 AM this morning and could not stop thinking about how the stove would perform with the fans installed. Um. Fans installed by 2:30AM! Mine were very tight fitting at the top. Had to get a bit aggressive with them to finish the install
. My wife now knows that instead of thinking I was crazy. I proved it. What on earth are you doing in the middle of the night? Um.
Sooo. I can say that the fans have made a dramatic difference getting the heat dispersed. I had a inkling I was not taking full advantage of the heat being produced before the fan install. Very pleased and relieved.
On another note. While waiting for the fan kit to arrive I had been running a standard box fan pointed at he side/back corner of the stove since I installed it. I must of set it to close as it seems that the box fan had been interfering with the thermostat. Before the fan kit install I had experienced strange mood/temp swings on my external pipe temps. flame/no flame control. Etc. After getting rid of the box fan (which was absolutely required to circ. heat before) my stove has settled down completely. I can only guess that the box fan was goofing up my intake air control. Also. Before installing a new fan kit I would strongly recommend plugging them in and running them to assure the fan blades have no interference as delivered. I had to remove one fan (that I had fought to install naturally) and take the fan guard off to relocate the fan speed control box a smidge. Otherwise the fan was very loud as the blades struck the control box (approximately 2:15 AM)
