Outside air yes, living envelope air no. With my old OAK-less stove my wife would have to open a window to prevent the kitchen exhaust from sucking smoke out of the stove. When she forgot to open the window I got into trouble. Thus the OAK.
OAK is always better than no OAK, but you must live in a very small and/or tight house to have an issue like that. We can run multiple dryers, kitchen exhaust, and four bathroom exhaust fans, without any noticeable difference in stove draft.Outside air yes, living envelope air no. With my old OAK-less stove my wife would have to open a window to prevent the kitchen exhaust from sucking smoke out of the stove. When she forgot to open the window I got into trouble. Thus the OAK.
I do 24 hour burns routinely with partial loads. It used to really exciting, now it's just a normal part of owning a BK!
Heck I'm the original creator of the BK performance thread.
New season, new thread.
I think you just did and it was just fineHI, I am new to this page as well as burning. I am trying to figure out how to ask/post questions. Could you advise?
@bigaar , i can only think of three reasons to install an oak.
1. competing draft. my next house will have a kitchen exhaust fan rather than a circulating fan in the range hood. clothes dryers can move enough air to compete, kitchen exhaust fans are the more common culprit.
2. tight enough construction to use an hrv. if you are building that tight an oak will save drawing all your combustion air through the filtration system, and make the house side of the system easier to balance.
3. prevailing wind and local topography.
For the first two i would put the oak in with the stove. if you are concerned about the third i would figure out where the oak will fit through the framing, run some burns and onmy install the oak if you need it.
4 actually, some local codes now require oak with new installs.
I have nevwr worked with foam insulation. from reading about it i would install the through floor pipe and spray around it for better final seal rather than soray, cure and cut.
I burn about 8 cords annually in my ashford 30.0. i am burning all spruce this year, 12 hour burns are easily achievable with a tightly stuffed firebix and moderate tstat setting.
I persoanlly would burn the hardwoods in shoulder season where the long coaling phase might get me 24 hour burns in mild weather.
In colder weather i prefer softwoods because they dont have a lengthy coal stage allowing me to refill the box with fresh wood and more dried up sap; keeps the btu output higher.
When i am running the stove hard and see a bed of coals getting bigger and bigger i know its time for softwoods.
5. Without an OAK, you consume warm air from the house to feed the fire. The replacement air has to come from outside, leaks in through your doors, windows, etc. You end up with a net air current TOWARD the stove. It's much easier to end up with uneven room temperatures this way.
Also, you might end up bumping up the thermostat to compensate for the cool air drawn into the house. Thus, some people experience longer burn times with an OAK.
All true, but in older homes where mold is more likely to be an issue some air turnover is good and cord wood is much cheaper than mold abatement.
Have any of you guys played with your tstats much? Trying to figure out the difference in the one that is in my siracco 25 vs the princess and others.
When you guys set yours to low does the butterfly fully close? Even when the stove is cold?
I hear mine click shut around the middle of the normal range, when I turn it down after my 20 minutes of high burn, after each reload. When it's cold, it clicks shut a little lower. I haven't measured the clock locations where I hear it click shut, but I'd guess around 4 o'clock when hot, 2 o'clock when cold.Have any of you guys played with your tstats much? Trying to figure out the difference in the one that is in my siracco 25 vs the princess and others.
I would suspect the butter fly should be open (calling for air to make heat)butterfly looks like at the lowest setting with the stove cold
![[Hearth.com] 2016-17 Blaze King Performance Thread (Everything BK) [Hearth.com] 2016-17 Blaze King Performance Thread (Everything BK)](https://www.hearth.com/talk/data/attachments/188/188724-c94c30d77b38b409fd1972471e418708.jpg?hash=awyb-ca5Mk)
Do you guys have pictures of what your butterfly looks like at the lowest setting with the stove cold?
remember mellow, all of our throttle blades have a decent sized hole punched into them.
Is she aware that she is no longer your daughter?The old daughter and I were watching the stat cycle last night.
I've run my Princess insert hotter by accident without harming it, but that photo is hotter than I would run it in purpose.
If it gets too hot, and you need a lot of heat in the house fast, just turn up the fan. If you don't want the additional heat, turn down the thermostat.
In theory, if you left it on high, it would throttle down and not be damaged, but this assumes your thermostat is correctly calibrated and undamaged, and that your gaskets are good and tight.
If I saw mine headed above the active region, I'd probably do my 20 minute "high burn" at less than maximum setting. Remember the intended goals of the high burn:
1. Burn off the creo crap that accumulates in the firebox during any prior long slow burn.
2. Bake any remaining moisture out of the wood, so the cat can easily stay active during the long slow burn.
You can do this at any setting that maintains strong flame show, without completely cooking your cat at 2000F. I'd find the setting that keeps the cat in the middle of the active region, and if that setting has strong flame show, I'd just do the 20 minute "high burn" there, at least until your cat reaches sufficient maturity to not go nuclear.
