Excavator
With my seasoned wood and strong draft I don't see much smoke if any at all at 1000. If I run hotter than 1200 she will slowly climb up to 1700 and then come back down but I hate when that happenes
Gotcha. I can turn it down at 1050ish and she will cruise right in the 13-1400 range. All my wood is 15% range.With my seasoned wood and strong draft I don't see much smoke if any at all at 1000. If I run hotter than 1200 she will slowly climb up to 1700 and then come back down but I hate when that happenes
> key should work to silence unless your numbers are backwards.....Ok I got my AT100 up and running this morning. So far its looking good. I had to switch the probe type to K in the setup menu and set the alarms but all else is good.
Whats the deal about silencing alarms. I pushed the > key but it didn't work... I got so annoyed I turned off the low limit for now and just have a high at 1600 until I get the hang of it.
J harken if alarm low is higher then high it will not shut off. Just recheck
Correct. My AL1 is set at 800 AH1 is set at 900. When my thermo is operating correctly the alarm sounds at 900. Push > button and it is temporarily turned off. Once temps fall below 800 the alarm is suppose to be "reset" and ready to sound again once we climb back up past 900. For some reason my alarm doesn't always sound again after a reload.I thought that was how you make it a high limit alarm, have AL lower than AH ??
My sounds again on every reload. Maybe try replugging at each reload if all else fails?Correct. My AL1 is set at 800 AH1 is set at 900. When my thermo is operating correctly the alarm sounds at 900. Push > button and it is temporarily turned off. Once temps fall below 800 the alarm is suppose to be "reset" and ready to sound again once we climb back up past 900. For some reason my alarm doesn't always sound again after a reload.
I have noticed if I unplug the unit from time to time it will work better however my second alarm has never sounded. I will have to see if Auber is willing to warranty it out. I feel you should be able to leave it plugged in at all times and both alarms should work every time.My sounds again on every reload. Maybe try replugging at each reload if all else fails?
Does anyone ever empty their ash pan? I stopped using it and just shovel out the bottom of the fire box once in a while.
Mines been plugged in 24/7 for weeks so yea try to swap it.I have noticed if I unplug the unit from time to time it will work better however my second alarm has never sounded. I will have to see if Auber is willing to warranty it out. I feel you should be able to leave it plugged in at all times and both alarms should work every time.
Jharkin - In regards to your temps slowly creeping up, I have tries several attempts of after cat hits 900 - 1100 and if I play with air control right at 1000 it seems to make big difference. At 900 and cutting air down to half it can stall, at 1000 it might or might not stall but anything above 1100 and it will creep slowly up above 1600 or 1700 but then come back down slowly
How was the glass in the morning?I put in the last load yesterday at 9pm. Full (but not packed) load and a lot of coals and using the auber was able to shut the damper much earlier than usual and know it was lighting off. The gauge temp was rising so I closed the air to half really early around 800 then at 900 started shutting down and had it full closed by 1000. The load was not even fully charred at that point but this is very dry 3 year hardwood. I think this point really helped it burn slower and not overwhelm the cat. Overnight temps in the high 20s.
I reset the max to let it record and based on what I found this morning it peaked out at 1280F around 1am. Its nice to be able to go to sleep knowing that if it got near overfire the alarm would wake me.
I can see why you guys like this thing so much.
I took the andirons out and load the stove to the top of the griddle just about every time. That is how I get to 9-10 hours between reloads on my encore. I usually stuff it full in the morning (6-7am) Put in a smaller-ish load around (3-4pm) and then stuff it to the gills at around 10pm once more.
