Ashful
Definitely, but even that old Firelight gets better burn times than most new stoves owned by our forum members. So, add PE, Quad, VC, Harman, and as many others as you'd like to that statement.Than what, a Firelight 12?![]()
I got the order in today, it's def a high density gasket, but it's not solid white, the outside had a charcoal jacket, solid white internallyI will not risk getting a non oem part. Hecklers seems to be the bk part. I'll try my bk dealer first if he can handle shipping it.
What exactly have I done?I think webby3650 has done that but I don't believe he's a golfer.![]()
Post #1441 and #1442, "Then he showed me how well his BK Ashford....burned wet wood."What exactly have I done?
I don't typically burn "wet" wood, but I've been in a pich on occasion. These stoves are much more tollerable of under seasoned wood than many others I've ran. I really doubt I'm the only one that's found myself in this situation.Post #1441 and #1442, "Then he showed me how well his BK Ashford....burned wet wood."
I agree this seems to be true of cat stoves in general, but this is exactly the opposite of the claims I read from most others on this forum. Bottom line, a cat can keep secondary burn going at a much lower temperature, so why would they not be more tolerant of maintaining secondary burn with poorly seasoned wood? The answer may be in ceramic cat durability, but SteelCats have overcome the issue of steam impingement.These stoves are much more tollerable of under seasoned wood than many others I've ran. I really doubt I'm the only one that's found myself in this situation.
STOP!! Do not burn your stove as you have this installed!! Fresh air can not be run higher than the bottom of the firebox!! Doing so can reverse draft in a perfect storm.The parts I ordered came in Thursday, here are some pics, I added a OAK and convection deck, I was nervous about adding the oak due to the fact of having to punch a 4" hole into the foundation, but it wasn't that bad, I did a 4" hole on the outside for a dryer vent, cut the vent pipe down and added a 4" to 3" reducer and elbow and did a 3 1/2" hole on the inside, I took a can of spray foam and filled the cavity up, sealing everything good. The I ran about 6 1/2ft of solid 3" pipe straight down to some 3" metal flex pipe (comes with the oak kit) and (2) 90's attached to the oak plate on the stove, this took me about an hour to do and was real easy.
The convection deck was even easier, clean the top of the stove, take the smoke pipe off, lay plate on, reconnect the smoke pipe. I like the convection deck, it seems to really focus the air coming out of the blower over the top of the stove, the heat just oozes out when the blower is running low.
View attachment 172143 View attachment 172146
Chris
I very rarely run into an install that would require the OAK to be above the firebox. 90%? Maybe 10% around here.90% of all installs here require an OAK above the firebox. My permit actually requires an Outside air connection.
So, do you recommend I disconnect the OAK at the stove and leave it resting near by?
Chris
Is that in the manual? The draft could reverse with no oak and dump the smoke into the house. Might be better to send it up the oak to daylight.
