fireplacenoob
I do exactly the same thing, but load all at once on top of the kindling so less fuel. I use very low btu softwoods (mostly cypress/juniper/cedar right now) but still get 20 hours on my worst day when running low.
How are you identifying the end of your burn time? Is it when the cat meter goes inactive? That's what BK uses. Also, when the stove is cold, does your cat meter point to the bottom of the inactive range or way below.
The fans being on will on will reduce burn time but will also artificially lower the cat probe reading.
Ok, I might be on to something here. So, first, an issue. I tried the dollar bill test, and if I pull hard and carefully, I can slide a dollar bill sized paper without it tearing in about all locations of the door. This is a 6month old stove, maybe it came adjusted incorrectly? Thoughts?
Secondly, time measuring. I played around with my thermostat settings and listened for the clink, and I could keep my meter at 2o clock position active, with the thermostat at level 1 and burned for easily 12 hours, could have kept going. But the heat output was insignificant and served no purpose, my furnaces were still running as usual (2800+ sqft home, 2 story, new home). So I guess I really can get 12-16 hour burns, but the heat output is insignificant and Im guessing it is simply because the square footage of the home. Correct me if im wrong?
If I burn at around 1.5-1.75 I can keep the entire house warm for about 7-8 hours at 72 degrees (got little babies)
was able to push it back in with just a light push.
