Reckless
At times its only a suppliment. Also you dont keep your GT up in the 700's!Wow you are heating 3000ft2 with an encore?! Wow. I'm at 1400 andit struggles when we see single digits...
Mine appears to close completely. Whats everyones obsession with the primary closing completely? The ONLY time I could ever close it completely and not have secondary backpuffs is when in coal stage. A wise man told me one important tip about this stove, if it isnt operating correctly replace your gaskets and if that doesnt fix the problem replace them againHi. My 2550's primary air flap does close all the way. I actually hear it click. The problem is that the flap itself is about 1/4 inch too small from the bottom lengthwise. This leaves a gap when fully closed. Does your primary air flap cover the entire opening or does it have this gap? Thanks!
The cat hit a 1000 in 10 min? It should be engaging in 5 and then you can back off primary.Yeah my secondary damper was around 1/2" open when cold. My primary flap will completely seal (no openings) when dampered down. It rose to 1000 in about 10 minutes after engaging the cat. I am thinking my wood is way too dry. Also thinking about changing the combustor since it's the original, 20 plus years but not much smoke when engaged, and looked good when visually inspected last year.
Im still missing what you mean. Do you have a probe and are these the readings from it? Or are these griddle temps (I hope your griddle isnt at 1000)Cat engaged at 600-primary closed temps went to 1000 for about 15 minutes or so.
Yes, griddle temps, seems I am still getting air in from somewhere, even when dampered back. Fully closed.
Sounds like you have an air leak or a bad thermometer. Do you have a second thermometer to test it with? 1000GT is crazy hot. Let it cool down to coals and start checking gaskets with the dollar bill test.HOLY chit! Griddle temp at 1000!
If I understand correctly you get GT of 700 with primary all the way down? I keep mine around 700 no problems (1/2-3/4 open primary), Cat temps are more important to me. My stove operates in two ways high GT and lower CT (day burns) or high CT and lower GT (overnight burns). High GT and High CT is a runaway stove and can lead to a overfire. If your stove is climbing that fast with the primary almost closed you have an air leak.Woooo, my mistake, it was a little over 700. Sorry about that, I purchased a new condor stove top thermometer last year and with my old eyes read it wrong. So it jumped up around 700-800 for a bit with everything dampered down and never choked down at all, with the windows clean the whole time. I never put over three splits (usually two) in for fear of over firing. Thanks
Running these stoves with no probe is like putting a blind man in a maze..... seriouslyThanks reckless, I'm gonna start checking gaskets again. May get a probe and monitor the combustor too.
This could be your mid burn stall problems too...... stupid new technology XDYes thanks Glenn Im getting very suspicious of the steelcat. This is the second one that's acted this way... Curios what BBar uses as he has the same smoke problems I do.
I tried calling Condar just now but they are closed through New Years. I am going to ask them to swap mine out for a Ceramic, see if that improves things. (fingers crossed).
