Correct. Running in updraft mode for long periods of time will damage the stove.ermm, pretty sure your stove is not meant to run in bypass mode...only for fire starting and reloading...
Not with a 1945. Cat mode is with the damper engaged and bybass mode is of course with the damper not engage. As far as damaging the stove in bypass mode as long as I am not over firing the stove how would it damage the stove? I am running the stove at around 400F griddle temp in bypass mode and it runs just fine. Efficient... Of course not but it is a pretty fire. I also burn the stove with the doors open a lot as well.
Thanks again,
Glenn
For me, it seems to be the same. The Defiant tends to get soot spots when a split is touching the glass. Since the doors and firebox are so much larger than the Encore, splits against the glass happen more on the Defiant than the Encore.Agreed. Would you guys say that the Encore's keep their glass a little cleaner then the Defiants?
Thanks again,
Glenn
Not over here. Next ten days have highs in the 30s and 40s. Mostly seasonal average stuff.Gentlemen, time to lock and load our stoves. Get out that special stash from your woodshed. Its on!
When you talk about dirty glass do you mean black soot or hazy grayish film? I get the haze but never the black soot. On ocassion as BBar mentiond a split will shift and touch the glass, a black spot will develop but it is always gone once the stove is ready for a reload. Keep in mind the 0028 has double glass and i think that is the main reason for the clean glass. When I had the 1450NC the glass would sometimes get the black soot but it was surly due to questionable wood and me trying to close down the air too soon.
Hey Diabel, I am referring to the black baked on stuff. I have yet to get the white fly ash that some of the guys have spoken about. Also I wanted to ask what you meant by the 0028 having double glass?
Thanks again and Merry Christmas,
Glenn
