Does anyone elses door gasket start shredding way too early? The top notch on the left door seems to take alot of damage from the right airwash screw. Maybe slight misalignment?
OK, in the calm before the storm.... mid season pipe check. I have bout an inch of creosote chips fallen into the cleanout. Pipe has what looks to be about a 1/8" coating, mostly brownish at the bottom looking blacker up toward the top. I can see some flakes up top as well. This is after only 3/4 cord or so
This is worse than I was hoping for, but not as bad as last year. I hope that I can get Condar to exchange my steelcat for a ceramic and that cleans things up.
View attachment 122173 View attachment 122174
Ceramic cats for both stoves. I would have responded sooner, but again, I was never alerted to this thread being updated.Yes thanks Glenn Im getting very suspicious of the steelcat. This is the second one that's acted this way... Curios what BBar uses as he has the same smoke problems I do.
I tried calling Condar just now but they are closed through New Years. I am going to ask them to swap mine out for a Ceramic, see if that improves things. (fingers crossed).
I'm not sure how much I have burned in the Defiant since I run multiple stoves, but I had about 4" of build up at the bottom of the tee in the chimney when I cleaned last weekend. It was less than this point last year, but but still far too much. There was not much buildup on the pipe or the cap. I have no idea where the 4" of flaky crap is coming fromOK, in the calm before the storm.... mid season pipe check. I have bout an inch of creosote chips fallen into the cleanout. Pipe has what looks to be about a 1/8" coating, mostly brownish at the bottom looking blacker up toward the top. I can see some flakes up top as well. This is after only 3/4 cord or so
jharkin I think you have no choice but change the cat to ceramic.
I pulled my cleanout last week and was surprised how little i had since changing the cat back to ceramic and no smoke even keeping my secondary at 3 oclock position
Jeremy
In my opinion the pipe looks ok. The bucket with the loose stuff on the other hand....
On my set up that loose stuff falls back on top of the refractory box and it just sits there. This year there is about 1/3 of a cup of the loose flakes. And this is on a limping stove needing a major overhaul.
Good evening Guys,
I am trying to search these forums on my BlackBerry without much luck. Can one of you please provide a link to where a parts list is located or info on how to make your own CAT probe thermometer? I also wanted to see if any of you could answer the following questions: Why did VC build the Cat Encore's with the air wash system mounted to the doors and with the external door latch and the non-cat stoves with the same type of air wash that a Defiant 1645 or 1610 would have along with the internal type door latch? I ask because for one I always liked the look of the external door latch better and two it looks like the air wash system of the cat encores would just be more effeciant/better at keeping the glass clean as it would be forcing more of the primary combustion air over the glass as aposed to a Defiant or non-cat Encore. What I am thinking of trying is get one non-cat Encore in good condition (at least the castings are still good, I don't care about the ceramics) and find one cat-encore just for parts. Take both apart and mate the front door surround casting, doors and of course air wash system to the non-cat Encore. Then convert the newly built stove to the newer 2-1 system by replacing the old ever burn system. I know, I know... Kind of nuts. I work at a nuke plant and literally have twelve and a half hours to sit around and think about this kind of thing. Do you guys think it would work? Also as a side note, I just got my account with BAC so if you need any VC stuff let me know. I think I get 38% off book price and would be more then happy to help you with parts or a stove if I can.
Thanks again,
Glenn
Oh boy get that fire screen readyOK less then 5 min of bypass dropped to 1350, reengage and its now at 1400.. 1500. I'm going to stay up and watch it for a half hour to make sure it doesnt climb over 1700 again then hit thehay.
These stoves should get much longer burn times than they do.But so much for slow burning locust, after 3 hr its half gone.
